In one of the threads (I can't find it), someone said you get better quality using MN instead of the set XP's and SP's. Is this true and how did you determine this? I record my XP stuff in MN32 instead of XP. Also, someone wrote that they record 1 hour programs on MN31 giving you more bitrate for video and 256 AC3. When I record in MN32, I get 9.56mb/s VRB, and LPCM audio.
in MN32 (same as FINE) quality i get a video bitrate around 8mbps w/ 1.5mbps LPCM audio.
in MN31 quality i get a video bitrate around 9mbps w/ dd 2.0 ac3 @ 256kbps.
i cant distiguish the difference between lpcm audio & ac3 audio.. but i do feel better about having around 1mbps extra video bitrate.. not to mention an extra 5 minutes of recording time.
i was basing the bitrate on what powerdvd showed me... which is why i said "around" & "about"..
i cant really tell a difference, but if i were to make a choice between having an extra 1mbps of video bitrate w/ ac3 audio or 1mbps less video bitrate and lpcm audio, i'll go for the extra 1mbps of video bitrate.
https://www.videohelp.com/calc.htm
[MN31]
1 hour 5 minutes, 4.37gb, 256kbit/s audio, calculated bitrate = 9122kbit/s
[MN32/FINE]
1 hours, 0 minutes, 4.37gb, 1536kbit/s audio, calculated bitrate = 8227kbit/s
9122 minus 8227 equals 895.. almost 1mbps.
i'd rather have 5 minutes extra recording time & 895kbit/s extra video bitrate..
case closed
PowerDVD only gives the bitrate for the current frame you are viewing at that exact moment when you check it. It doesn't give you the average for the whole clip.
Bitrate Viewer is what you need.
Pioneer DVR
By vcd4me in forum DVD & Blu-ray RecordersReplies: 20Last Post: 25th May 2011, 01:33 -
Pioneer DV-F727
By captainneek in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Jan 2010, 14:59 -
Pioneer DV-420V
By Vasilii in forum DVD & Blu-ray PlayersReplies: 5Last Post: 14th Jun 2009, 08:28 -
Pioneer DV-410
By geroglifico in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th May 2009, 05:08 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02
