I am interested in this card to capture my Hi8 movies and burn them into DVDs. I am in the US and I know that this card is also a TV tuner.
Here is the deal - I don't care so much about th tuner, but my Hi8 movies are all in PAL.
Assuming the card that is sold in the US is NTSC, will I still be able to capture PAL Hi8 movies?
Thanks for your help.
I'm sure somebody will correct me if I am wrong but I think as long as you use the s-video or composite input then you can record PAL or NTSC.
He's a liar and a murderer, and I say that with all due respect. -
Don't know about the 150 but the PVR-250 was shipped as either NTSC or PAL, not both.
That's just the tuner though isn't it? I don't think it affects the s-video and comp input? I'm sure i've read on here that is the case, or maybe I dreamt it
Edit: http://www.cask-of-amontillado.com/pvr_reg.html#_Enable_Both_NTSC -
I know that, and I am quite sure I am gonna get the NTSC tuner...that's fine. My question is - does the fact that this is a NTSC tuner also effects the S-Video input signal as steveryan mentioned.Originally Posted by edDV
edDV, not quite correct, steveryan has the link
The tuner portion is either PAL or NTSC, the composite and s-vid portions don't care.
Most of the new PVR-250's will accept either a pal or ntsc signal through composite or s-vid with no trouble. The software determines the aspect/framerate, with a little help from the hauppauge drivers, which default to a GOP of 15 anyhow.
I believe this is true for the 150 as well.Cheers, Jim
My DVDLab Guides
[Sloved] Hauppauge WinTV PVR-150 capturing using off air cable plug
By Wizard23 in forum Capturing and VCRReplies: 4Last Post: 11th Feb 2011, 22:07 -
Hauppauge 150: Another Odd Problem
By Tom Saurus in forum Capturing and VCRReplies: 0Last Post: 12th Jun 2010, 12:22 -
Hauppauge WinTV PVR-150 ($60) vs. ATI TV Tuner 650 ($100)
By RoganSarine in forum Capturing and VCRReplies: 2Last Post: 13th Dec 2007, 03:48 -
Hauppauge 150, good or bad?
By SerbianBoss in forum Capturing and VCRReplies: 21Last Post: 4th Dec 2007, 10:24 -
You folks were right, Hauppauge 150..
By The Fred in forum Capturing and VCRReplies: 3Last Post: 8th May 2007, 14:39
