  1. What's the "best" way to author a DVD from mpg files that contain left and right channel audio tracks? I'm trying to compile a karaoke DVD from mpg files and have tried Nerovision Express but it doesn't transcode the the left and right channel separately so I end up with one audio track containing both channels. Can someone offer some insights into this please?
  2. Member daamon's Avatar
    Melbourne, Oz
    Hi Iron_Monkey,
    If I understand you correctly, and you want separate audio tracks, then an authoring tool like DVDLab Pro does multiple audio tracks.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. Originally Posted by daamon
    Hi Iron_Monkey,
    Hi Daamon,
    I've yet to try this software but I'm actually not trying to separate the audio tracks (not sure if that's what I need to do in order to make it work). I have karaoke videos in mpg format that has two audio tracks (left and right channel, one w/o vocals and the other with vocals) and have been able to create simple VCDs with Nero with selectable left and right channel audio tracks. I basically want to do the same thing, except to create it on DVD as I can fit 4 times as many videos as a VCD. How would I do this?
  4. Member daamon's Avatar
    Melbourne, Oz
    Hi Iron_Monkey,
    I've not needed to do this, but my suspicion would be that you'd need two audio tracks - one with the left channel only, and the other as right channel only.
    Then author to DVD with seectable audio tracks. Others may have a better suggestion...
    Carpe diem.
