I want to know how can I save the source aspect ratio when I convert a movie in TMPGEnc. I use the Clip frame option to add pixels in the top and in the bottom. but I want to save the source aspect ratio so I need to add pixeles in the Right and in the Left.
How can I calculate the pixels in the right and in the left for save the source aspect ratio?
whoo the wot the 20:9
hummm, set you output to 4:3, what matters is the way you input the avi...... in most cases its just a 1:1 ratio (just the resolution is wider - not anamorphic) so pick this as your input aspect ratio. 8)COOKIEEE!!!
Adding 15 black rows of pixels to the top and bottom of an entire clip
By Terrah in forum EditingReplies: 8Last Post: 20th Apr 2010, 21:48 -
how do I convert a video that shows square pixels to no pixels?
By sxpredman in forum Newbie / General discussionsReplies: 4Last Post: 10th Jan 2010, 02:56 -
Another question: Converting square pixels into round pixels.
By Earthling2000 in forum Newbie / General discussionsReplies: 13Last Post: 23rd Nov 2009, 10:20 -
Strip off a few pixels at the end of every frame in a video
By iBeech in forum EditingReplies: 8Last Post: 22nd Dec 2008, 16:45 -
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 22:53
