I downloaded a movie off the net in avi format and About 50 mins into the film , it starts juddering or shaking till the end. Is there a video editor or anything that will fix this? Thanks In Advance
Dude, I think it's joke. Like in, that's what you get for downloading an AVI from the internet. They are almost ALL crap quality and have all sorts problems with playback. If the juddering and shaking as you put , is in the video source itself, there unfortunately is really nothing much you can do about.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
You could try running it thru the addon deshaker filter with virtualdub...
Its weird cause when i play the avi with nero showtime its doesnt do that just when i play it with windows media player and classic. I wanted to convert it to dvd so i used winavi and the playback of it still has the juddering. Im going to try this deshaker filter with virtualdub... that zoobie suggested thanks for your help everyone.
I have the same issue
I used virtualdub with the deshaker and it works but you have to select full processing mode to enable the filter. I took a 17 meg section of the film just to test and virtualdub in full processing mode turned this into a 1.3gb file so imagine what a 700meg file will be.
I have a post on here called jumpy avi - have a read someone made a suggestion of playing the file on pc with a program called VLC media player, it is really good and sorted out the juddering but can only be used to watch the film.
Regards
M9G
Juddering in encoded HD video
By akkers in forum Video ConversionReplies: 113Last Post: 7th Jan 2012, 06:13 -
Video techniques - shaking zoom in and zoom out effect?
By Mylo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 12th Oct 2011, 11:08 -
DVD video appears distorted/shaking on sides when played on TV
By Blueknight in forum DVD RippingReplies: 0Last Post: 6th Feb 2011, 16:48 -
Trying to Reduce Juddering and Flickering
By Xenon77 in forum EditingReplies: 8Last Post: 17th Jul 2009, 16:58 -
What causes this juddering or stuttering artifact on captured video?
By brassplyer in forum Capturing and VCRReplies: 26Last Post: 3rd May 2008, 20:40
