Results 1 to 30 of 32
    Apr 2003
    I am trying to burn a bin/cue file to a cd-r using Nero 6 and when selecting the cue file i get an error saying,
    An error occured while loading the cue sheet file C:\(file location) (line1)
    Any ideas why this could be happening and hoow to fix it?
    I have never had this problem before with bin/cue files
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    open up cue file with notepad and edit the first line so it does not show a path
    covered in a sticky here also
    Apr 2003
    Opend it with notepad but does not show file path jst say 'FILE (file name).BIN BINARY
    TRACK 01 MODE1/2352
    INDEX 01 00:00:00
    canada
    Make sure the file name in the cue file is exactly the same as the bin file name.
    Apr 2003
    They are the same file names in the folder apart from bin and cue obviously
  6. I'm a Super Moderator johns0's Avatar
    canada
    Something is wrong with the file names if the bin file is ok,make sure the first line in the cue file looks like this-
    FILE "(file name).bin" BINARY
    'FILE (file name).BIN BINARY ,that doesnt look right with the quotation marks missing.
    Apr 2003
    The cue file does have the "" at where johns0 said they should be
  8. Maybe you should enter the full file name - with the path.
  9. Here s a little trick I sometimes use.
    Right click the bin file name and choose 'rename'
    When the name is highlighted, press Ctrl-C (Copy)
    Open the cue file in notepad, highlight the name of the bin file in between the " " and press Ctrl-v (paste)
    Save the cue file
    Open with Nero
    Often, there s one character that s wrong somewhere in the cue file in referencing the bin file, this ensures that the bin filename is spelt properly.
    Apr 2003
    Thank for the tip aguillon but i had already tried that but unfortunatly it didn't work, any other suggestions?
  11. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Post the full cue, together with the full path of the cue and bin files.
    /Mats
    Apr 2003
    When you say to post the full cue you mean open it with notepad and copy/paste the info in that file?
    Apr 2003
    Ok i will do it as soon as i get home 2night
    Apr 2003
    Mats this is what i get in the cue file:
    FILE "Filename.bin" BINARY
    TRACK 01 MODE1/2352
    INDEX 01 00:00:00
    And here is the file path for both bin/cue:
    Bin File: G:\Games\file name\CD1
    Cue File: G:\Games\file name\CD1
  15. Originally Posted by Squid_uk
    TRACK 01 MODE1/2352
    INDEX 01 00:00:00
    I assume your files are CD1.cue and CD1.bin. If so the top of the cue file should read
    FILE "CD1.bin" BINARY
    If this doesn't work put there
    FILE "G:\Games\file name\CD1.bin" BINARY
    Apr 2003
    i tried both of those and nither worked
  17. Член BJ_M's Avatar
    Jul 2002
    Canada
    use another program to burn the cue sheet , or load it in DAEMON and burn it from that
  18. i don't do alot of bin-cue but can't you just have nero open and load the bin without the cue? when in nero after you say burn image, if you look you see both the bin and cue when selecting which file to burn. your cue is not matching bin file.
    Apr 2003
    ok i have use daemon to open it an it worked but i cant seem to find how to burn it?
    any help?
  20. Член BJ_M's Avatar
    Jul 2002
    Canada
    burn the contents of the DAEMON CD to a blank CD
    Apr 2003
    no sure if im following you here
  22. Член BJ_M's Avatar
    Jul 2002
    Canada
    in explorer you see a new drive letter which is a cdrom drive ..
    if you look in that 'drive' , there is some content ..
    open nero and burn what is in that 'drive' onto a blank cd in mode 1 format
  23. Member
    Apr 2003
    i cant seem to find anything in the drive
  24. Member
    Apr 2003
    GOT IT I ThinkDo you burn all the data in the drive with nero using the burn data disk function?
  25. Член BJ_M's Avatar
    Jul 2002
    Canada
    yes -- but watch the mode you use, you might have to use mode 1 if it is a vcd or svcd
  26. Member
    Jun 2005
    Canada
    can i put cue on dvd. and if i can could I put 2 cue
  27. Член BJ_M's Avatar
    Jul 2002
    Canada
    no - not in the way you are thinking
  28. Member
    Jun 2005
    Canada
    in witch way then
  29. In witch way - yeah, should be right
    Cue files are simply text files. You can put many,many,many cue files on DVD.
