I have an avi with 48k audio. i converted it to vcd so i can keep the 211mb size but the audio changed from 48k to 44k and the audio isnt matching the video. is ther a way to convert to vcd and keep the 48k audio? what program do i need.? also, is that a possible reason the audio and video doesnt match now?
The VCD specification calls for audio at 44100 HZ, MPEG-1 Layer 2 (see here). If you want it to comply with the VCD standard you don't have a choice of 48K.
If the sound and video were in sync before you converted it, then yes, the conversion is probably responsible for the loss of sync. What did you use for the conversion? Did you use an all-in-one converter program? Did you demultiplex, use an audio converter (like BeSweet), and then remultiplex the streams? -
i used cocusoft avi converter to convert it to vcd (mpeg), then i used VirtualDub to import the subtitle with subtitler and started the frame server. after that i used tmpgen to hard code the subtitles. this is the exact process i did so i could make it dvd ready with hardcoded subs.
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 07:36 -
48K or 33K audio setting
By devdev in forum Capturing and VCRReplies: 3Last Post: 3rd Sep 2010, 07:32 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 18:24 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 09:02 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12
