  1. Member lumis's Avatar
    Jan 2005
    the remnants of pangea
    i bought an archer variable gain video amplifier, new, from a pawn shop for $2.. i figured it might be handy for transferring macrovision protected vhs tapes to dvd.. i've used a sima video clarifier before, and it seems to do the job.. but i'm not entirely sure about this device.. it was only $2, so even if it doesnt, no big loss.
    the brand name is archer, and its called a "variable gain video amplifier", i think it was distributed at radio shack. it has a rca video input, and rca video output, and an adjustable gain control (min/max)
    any info would be appreciated.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    usless for anything pretty well ... yes sold by Radio Shack (and a RS name brand) , but noisy as hell and pretty well not needed for anything except long cable runs (and still wrong tool for the job) or for low output on a vcr or something (pretty rare)
    Mar 2003
    Third Rock From The Sun
    What device would be good for long cable runs??
    "The name on the front of your shirt is more important than the name on the back"
    Kurt Russell - Miracle
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    one that has at least adjustable gain and equalization for different cable types and lenths , all the better ones do.
    Archer equipment is noisy.
    I have an extra proc amp and a detailer made by them that I need to re-sell. It's not "bad" necessarly, just not as good as vidicraft and others.
  6. Member lumis's Avatar
    Jan 2005
    let me make sure i got you right..
    a) it wont clear up macrovison
    b) even for its intended use (long cable runs, low output vcrs), its crappy
    does that pretty much sum it up?
  7. Член BJ_M's Avatar
    Jul 2002
    Canada
    yes - good sum up
