Here's the situation: I backed up all my data on a USB hard drive. Then I reformatted. After the reformat when I tried to load to load my data onto the hard drive I discovered that the device won't start-up. I have already sent an email to tech support but I would like to recover as much data as possible from the hard drive itself. What program do you guys suggest?
PS: My OS is WinXP Pro SP2.
Thanks for your help,
-Jonathan.
Results 1 to 10 of 10
take the drive out of the USB case and mount it inside your computer first ...
It's a 2.5" drive, does that mean it will only fit in a notebook?Originally Posted by BJ_M
yes --
I think there are bridgeboards that will convert that ATA-6 or whatever the interface is on that 2.5" drive to your regular 80-pin ATA connector. Is the data worth that much to you?
FB-DIMM are the real cause of global warming -
If you REALLY want the best, then I recommend Ontrack EasyRecovery Professional 6.04
But, be prepared for sticker shock when you see the price.
I use it professionally to recover data from drives so broken that the OS won't even recognize them as being present.
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
Restorer2000 has worked great for me, and I've used it on a firewire drive with no problems
runtime getdataback ntfs version
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
A Sircooks commented, getdataback ntfs.
My main 80gb crashed a little over a year ago and after trying a few of the 'online' demos, getdataback seemed to work the best and at that time did not have a limited purchase-use feature, some I looked at would only work for one year - can't remember the names though.
I was able to recover about 98% of the data.
Hope this helps -
another vote for getdataback it works quite nice and you can run it to see what is recoverable BEFORE purchasing the software. Also there are conversion kits to convert the 2.5" drive to normal ide. they are not that expensive either...
here is what froogle found
http://www.google.com/froogle?q=2.5%22+to+3.5%22+ide+adaptor&btnG=Search+Froogle
File Recovery
By KarlW in forum Newbie / General discussionsReplies: 1Last Post: 4th Feb 2011, 09:46 -
What is the Recovery file for?
By jyeh74 in forum Newbie / General discussionsReplies: 41Last Post: 8th Feb 2010, 15:19 -
Help Please: Looking for MPEG2-ts (Transport Stream) Recovery Software
By Moon43 in forum ComputerReplies: 13Last Post: 11th May 2009, 15:20 -
CD recovery software needed
By mysts in forum ComputerReplies: 8Last Post: 2nd Aug 2008, 15:28 -
File recovery - avi file thinks it's an m2ts
By chejrw in forum Video ConversionReplies: 0Last Post: 7th Mar 2008, 13:51
