Are there any burners other than Plextor that support Karaoke recording? Karaoke's grahics subchannel requires a special function in the burner to record Karaoke discs. The only one that I am aware of that supports this function is Plextor.
You may be confusing a number of karaoke technologies:
1. CD+G Karaoke: Requires authoring app that can format an audio track to include subcode material (R-W), CD burner that can burn the full 2448 kB sector (aka "DAO-96"), and also a player that can read and correctly decode the R-W subcode. Most can't.
2. VideoCD Karaoke: Use subtitle creator apps listed <-- and hard-encode ("burn-in") subs onto the video along w/music, encoding to mpg, burn as standard VCD. Play on any VCD or most DVD players as usual. Doesn't need anything special in the way of CD burner.
3. DVD Karaoke: Must have authoring apps that understand the special Karaoke features of the DVD spec (e.g. Scenarist, Maestro) and good multitrack audio editor to create the correct stems, but you're burning a DVD using the standard method, and so need just a standard DVD burner + app. Playing this correctly requires a DVD player that supports the special Karaoke features (e.g. Pioneer combo units).
I need help with Karaoke DVD to Karaoke VCD(MPG)
By adrianneow in forum Newbie / General discussionsReplies: 1Last Post: 8th Jun 2011, 10:02 -
How to Record using 3 External Burners plus 2 Internal Burners with Speed
By mn072065 in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th May 2011, 19:27 -
"On the fly recording" and two burners on same SATA channel
By Disco Makberto in forum Newbie / General discussionsReplies: 5Last Post: 30th Aug 2009, 03:36 -
how to convert LD karaoke to VCD karaoke ???
By sandmankeren in forum Authoring (VCD/SVCD)Replies: 1Last Post: 7th Aug 2008, 16:53 -
Ld karaoke to dvd karaoke
By volam in forum Video ConversionReplies: 0Last Post: 27th Mar 2008, 10:13
