Hi, I have a Leadtek TV2000XP Deluxe and also I have a Freeview box.
I was wondering, is there anyway I can view Digital TV on my PC via the TV Tuner Card?
The Freeview box only has 2 scart outputs, L and R audio outputs and 2 aerial connections.
On the TV Card there is only an aerial input and an S-Video input
Many thanks in advance.
You should have a Y lead with that card allowing svideo or composite input via the din socket. Get a scart to rca lead and use the audio L & R in connections to the back of the card and connect the composite video in connection via the Y lead.
Depending on what Freeview box you have, it MAY output S-Video, although most don't, only Composite and Component. Use a Scart to three phono lead (yellow, red & white) and connect to the S-Video input using the Composite to S-Video adapter that came with the card (as mentioned by nutstoyou above). In the software that you use to watch TV on the pc, select the S-Video/Composite input as your source.
Freeview box failure?
By aw56001 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 3rd Dec 2011, 09:22 -
Had freeview, Now it's gone!
By Squid_uk in forum Off topicReplies: 2Last Post: 23rd Sep 2009, 04:05 -
Freeview Box - File extension
By hesh234 in forum Newbie / General discussionsReplies: 1Last Post: 21st Nov 2008, 14:07 -
3.5" HDD into Freeview?
By Nitro89 in forum ComputerReplies: 3Last Post: 29th Apr 2008, 10:52 -
my freeview--no event info.
By ssaamm in forum Newbie / General discussionsReplies: 0Last Post: 26th Jun 2007, 14:33
