My mate transfered a video of my grans birthday onto DVD+R. We've just tried play it in a few macs at work and none of them can read it. Is there a quick fix – how I can read this disc. The main computer I work with is:
Dual 1.8 GHz G5
ATA-6 Bus
PIONEER DVD-RW DVR-107D:
Manufacturer: PIONEER
Model: PIONEER DVD-RW DVR-107D
Revision: A707
Drive Type: CD-RW/DVD-RW
Disc Burning: Apple Supported/Shipped
Removable Media: Yes
Detachable Drive: No
Protocol: ATAPI
Unit Number: 0
Socket Type: Internal
Is there anything else you need to know. Can I just update some software?
Cheers in advance.
PS
I need to work this out as quick as possible cause it's supposed to be a fathers day present.
As long as you are running OS 10.3 or 10.4 there should be no problem with mounting DVD+R media and playing those DVDs on that Mac.
If the DVD was burned on a standalone DVD recorder it needs to be finalized before it can be played on other devices, such as a Mac. -
OK - cheers for the quick reply. I'll get back to my mate cause he may not have finalised the DVD.
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 05:04 -
Capture on Mac - read DV on PC?
By maveni in forum Capturing and VCRReplies: 18Last Post: 5th May 2009, 09:01 -
DV files, read by both Mac and PC ?
By frd1952 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 07:45 -
forget compression, will a Mac G5 Pro/iMovie read an uncompressed AVI?
By nopk in forum MacReplies: 3Last Post: 8th Dec 2007, 23:26 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 16th Jun 2007, 23:04
