I moved my 2 DVD drive further up on my case and unplugged the cables to do so. After booting up the drives are missing. Hardware device manager had this to say plextor 712a and the HP 200I.
There was also an error msg when booting up that the dvice couldn't be fount. I deleted my plextor software and the message stopped. However XP couldn't find the dvd drives on the primary IDE."Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
Click Troubleshoot to start the troubleshooter for this device."
I tried :
* different cables
* 4 other cd/dvd drives
* all all of them work in other computers
* the drives on the primary IDE worked when switched to the secondary slot
* when hooking the DVD drive as slave to the prmary ide/main hard drive the system didn't see the dvd drive.
I'm still stuck after several days of trial and error and searching.
If anyone has an answer or suggestion, please chime in.
Did you try getting them recognized in BIOS 1st?
Sometimes you have to get the BIOS to recognize them 1st then save/exit/reboot.
USB capture devices vs USB tuner devices...... which are better for recording?
By True Colors in forum Video Streaming DownloadingReplies: 1Last Post: 31st Jan 2010, 16:04 -
canopus v other devices
By marada in forum Capturing and VCRReplies: 70Last Post: 26th Dec 2009, 21:38 -
Wireless PC to TV devices
By jrmy_1 in forum Media Center PC / MediaCentersReplies: 8Last Post: 23rd Aug 2009, 23:24 -
Where to find a ZIF to IDE adapter
By VirtualDoobMon in forum ComputerReplies: 8Last Post: 14th Apr 2009, 09:27 -
Help install my USB PCI card Windows 98SE,have driver can't find hardware
By bnbhoha in forum ComputerReplies: 6Last Post: 13th Feb 2008, 13:58
