I downloaded and installed the vfp, put the DVD2AVI.vfp and TMPGEnc.vfp in the same directory. But when I try to put eh video file *.d2v , I get this error:
TMPGENC caused an invalid page fault in
module DVD2AVI.VFP at 017f:018e1175.
I tried rebooting...Also don't know what Sefy means by "It is also sometimes helps to use the Forced Film option in DVD2AVI, but only if you are still unable to open the D2V files with TMPGEnc. (suggsted by msfox)
first, make sure you enabled this option in DVD2AVI under the HELP drop-down window:
enable VFAPI plugin
also, wut sefy's guide was referring to is to enable FORCED FILM in DVD2AVI under the VIDEO drop-down window -
I am still having problems getting TMPGenc to recognize the DVD2AVI file. I tried forcing. Could it be the vob files are corrupt and I should rip again?
try Reripping them if it still happnes then there is a problem with the DVD2AVI file
DVD plays, won't rip (now rips with CDRoller, won't import to TMPGEnc)
By koberulz in forum DVD RippingReplies: 14Last Post: 4th Dec 2011, 09:42 -
Why does converted HD to SD file show video as letterbox using Tmpgenc?
By Endoking01 in forum Newbie / General discussionsReplies: 9Last Post: 9th Jun 2010, 21:37 -
video file won't play. need to know what type it is - what codec?
By chriscaton in forum Video ConversionReplies: 7Last Post: 12th Jan 2010, 08:20 -
Programs won't reconize video file ?!
By Beastly Swagger in forum Video ConversionReplies: 1Last Post: 26th Jan 2009, 17:42 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08
