Results 1 to 11 of 11
    Jan 2003
    Nassau, Bahamas
    i live in the bahamas, and its going to be frigging hot this summer, i dont have an aircondition in the room i have my comp in, there is a window in the back of it though. what i wanna know is is there an liquid cooling system i can by seperately to suit my case, if so where can i find one, i dont wanna change case i just wanna add it on to my existing setup, in order to run cool water over my system...holla back
    "If u cant eat it - u dont need it"
    "Baby - If i dont hit it, Who will?"
    "Why is Abbreviation such a long word"?
  2. There are lots of liquid cooling systems as addons.
    From basic, to overclocker madness.
    Surf to your favourite computer site, and search for "water cooling".
    Cheers, Jim
    My DVDLab Guides
    Jan 2003
    Nassau, Bahamas
    any url with interesting systems
  4. www.newegg.com has some Thermaltake stuff, but there are much cheaper systems, that sometimes work better. Just do some googling for CPU water cooling systems.
    Cheers, Jim
    My DVDLab Guides
  5. A good starting point would be the CPU Water Cooling FAQ.
    -drj
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
    --Benjamin Franklin
  6. Member normcar's Avatar
    Aug 2003
    USA - IL
    Depending on your CPU, you may be able to get away with using the XP-90 (or its bigger brothers the copper version of the XP-90, and the XP-120). These are the best non-liquid cooled CPU heatsinks available. On my 1.8 it the temps is about 10F above room temp. On my 2.8 512MB cache, it stays at about 20F above room temp. On my 3.2 1GB cache, the temp stays about 35F above room temp.
    Some days it seems as if all I'm doing is rearranging deck chairs on the Titanic
  7. The benefit to liquid cooling, is that it's FAR quieter than a huge fan and heat sink.
    Cheers, Jim
    My DVDLab Guides
    Mar 2005
    Hostile Territory
    But remember to use one that has the smallest chance of developing a leak...otherwise.....KA PLOOWEY
    Is what we learn indeed a fact, or someones opinon?
    Jan 2003
    Nassau, Bahamas
    how would i know that, is there someplace that rates these things?
  10. Member normcar's Avatar
    Aug 2003
    USA - IL
    You might try overclockers.com
    Mar 2003
    Third Rock From The Sun
    The guys on this forum are pretty sharp:
    http://www.maximumpc.com/forum/
    "The name on the front of your shirt is more important than the name on the back"
    Kurt Russell - Miracle
