I was backing up a DVD using DVD Shrink 3.2, DVD Decryptor and NERO to a DVD +RW. I have a NEC DVD +RW ND-6100A burner. It went through the whole process and said it burned the files. I opened up the DVD and there are VOB and IFO files there. (When you look at the underside, it looks like there wasn't much information to the DVD.) It will not play on my DVD player which has been able to play DVD-RW discs. It doesn't play the first chapter on my computer but if I skip forward to the next chapters it will play those. (It doesn't automatically play on my computer.) It burned it first with Decryptor which it said it was successful. It didn't work on my player. I then tried NERO and it said it burned it successfully but still doesn't work. What did I do wrong?
I followed the instructions on this link for DVD-9 using DVDShrink https://www.videohelp.com/forum/userguides/141024.php#dvd5. When I started using the Shrink it said there was a "DVDShrink encountered an error and cannot continue. Failed to read file "d:\". Data error (cyclic redunancy check.)" After that I decrypted it in the ISO-read mode, using DVDDecryptor to create a file then have DVDShrink analyze it and I reauthored it using DVDShrink. I took only the Main part and one extra. It went through the whole process and said it burned it with DVDDecryptor. I tried to play it and it didn't work. I then burned the file from DVDShrink using Nero. That didn't play either.
Dvd Backup
By DIKYDO in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 09:30 -
DVD Backup
By sixleaf in forum Newbie / General discussionsReplies: 3Last Post: 8th Jul 2009, 01:50 -
Backup of a dvd movie using Ripit4me, Dvd Decrypter, and Dvd Shrink 3.2
By Gerald Sr. in forum DVD RippingReplies: 18Last Post: 16th Oct 2008, 16:55 -
Help with DVD Backup
By zeroplace in forum DVD RippingReplies: 3Last Post: 23rd Jun 2008, 10:48 -
DVD Backup
By romanstopme in forum Newbie / General discussionsReplies: 1Last Post: 27th Mar 2008, 09:38
