    May 2005
    Norway
    Who has the best OSX compatible tool, for encoding AVI files to DVD files Thanks,Motti
  2. Member terryj's Avatar
    N35°25.24068, W097°34.204
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
  3. Master of my domain thoughton's Avatar
    England
    Probably ffmpegX. It kinda depends what sort of video and audio are inside your AVI container.
    Tim Houghton
    Website • Photography
    May 2005
    Norway
    Thanks for your help
    I gather encoding AVI to DVD is a fairly slow process, so I want to set the right parameters before encoding with FFmpegX. If the source format is AVI and I want to encode to DVD for play on a standalone DVD player, what should I choose as target format? "DVD mpeg2enc" or "MPEG-TS" ( or none of these )
  5. Master of my domain thoughton's Avatar
    England
    I usually try DVD-ffmpeg first as it is about twice as fast as DVD-mpeg2enc.
    I also usually uncheck 'author as DVD' and check 'keep elementary streams'. Once I have my .mpg file I author a new DVD using Sizzle 0.1 (I have found in the past that ffmpegX's authoring abilities arent that great.)
    You should also double check the frame rate, aspect ratio and video resolution before clicking encode.
    The elementary streams are only in case something goes wrong. Once you have your authored video_ts folder you can chuck 'em.
    Tim Houghton
