Can anyone tell me why this burn failed? possiably from this log? I was burning a ts_video folder with dvd shrink.
1A22-0206-0530-1610-5715-1441*
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 7/22/2004 5:33:44 PM
Nero API version: 6.3.1.19
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Recorder: <SONY DVD RW DRU-710A> Version: BYX4 - HA 1 TA 0 - 6.3.1.19
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG SV8004H atapi Port 0 ID 0 DMA: On
DiskPeripheral : Maxtor 6Y160P0 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : SONY DVD RW DRU-710A atapi Port 1 ID 0 DMA: Off
CdRomPeripheral : IOMEGA DVDRW4224INQ-D atapi Port 1 ID 1 DMA: On
CdRomPeripheral : AXV CD/DVD-ROM 2.2a axsaki Port 2 ID 0 DMA: Off
CdRomPeripheral : AXV CD/DVD-ROM 2.2a axsaki Port 2 ID 1 DMA: Off
CdRomPeripheral : AXV CD/DVD-ROM 2.2a axsaki Port 2 ID 2 DMA: Off
CdRomPeripheral : AXV CD/DVD-ROM 2.2a axsaki Port 2 ID 3 DMA: Off
CdRomPeripheral : AXV CD/DVD-ROM 2.2a axsaki Port 2 ID 4 DMA: Off
=== CDRom-Device-Map ===
SONY DVD RW DRU-710A G: CDRom0
IOMEGA DVDRW4224INQ-D H: CDRom1
AXV CD/DVD-ROM I: CDRom2
AXV CD/DVD-ROM J: CDRom3
AXV CD/DVD-ROM K: CDRom4
AXV CD/DVD-ROM L: CDRom5
AXV CD/DVD-ROM M: CDRom6
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1535MB (1572384kB)
Free physical memory: 1008MB (1032364kB)
Memory in use : 34 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
19.6.2005
NeroAPI
8:54:03 PM #1 Phase 112 File APIProgress.cpp, Line 273
DVD-Video files reallocation started
8:54:03 PM #2 Phase 114 File APIProgress.cpp, Line 273
DVD-Video files reallocation completed (no file modified)
8:54:03 PM #3 Phase 111 File APIProgress.cpp, Line 273
DVD-Video files sorted
8:54:04 PM #4 Text 0 File Reader.cpp, Line 118
Reader running
8:54:04 PM #5 Text 0 File Writer.cpp, Line 124
Writer SONY DVD RW DRU-710A running
8:54:04 PM #6 Text 0 File AudioCompilationImpl.cpp, Line 817
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
8:54:04 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3899
First writeable address = 0 (0x00000000)
8:54:05 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3899
8:54:05 PM #9 Text 0 File Burncd.cpp, Line 3173
Turn on Disc-At-Once, using DVD media
8:54:05 PM #10 Text 0 File DlgWaitCD.cpp, Line 247
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 1677791 (372:50.41, 3276MB)
8:54:05 PM #11 Text 0 File DlgWaitCD.cpp, Line 259
Write in overburning mode: NO
8:54:05 PM #12 Text 0 File DlgWaitCD.cpp, Line 2162
Recorder: SONY DVD RW DRU-710A, Media type: DVD-R
Disc Manufacturer: AML -
Disc Application Code: 64, Disc Physical Code: 193
8:54:05 PM #13 Text 0 File DlgWaitCD.cpp, Line 420
>>> Protocol of DlgWaitCD activities: <<<
8:54:05 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 813
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 1677792 (1677792) = #1677792/372:50.42
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1677792 blocks [SONY DVD RW DRU-710A ]
8:54:05 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 984
Prepare recorder [SONY DVD RW DRU-710A ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3436118016, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
1677792 | lead-out | 1 | 0x00 | 0x41
8:54:07 PM #16 Phase 24 File APIProgress.cpp, Line 273
Caching of files started
8:54:07 PM #17 Text 0 File Burncd.cpp, Line 4183
Cache writing successful.
8:54:07 PM #18 Phase 25 File APIProgress.cpp, Line 273
Caching of files completed
8:54:07 PM #19 Phase 36 File APIProgress.cpp, Line 273
Burn process started at 4x (5,540 KB/s)
8:54:07 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
8:54:07 PM #21 Text 0 File DVDR.cpp, Line 1932
Recording mode: Sequential Recording Mode
8:54:07 PM #22 Text 0 File Mmc.cpp, Line 20464
Set BUFE: Power-Burn -> ON , Generic write control : ON
8:54:07 PM #23 Text 0 File DVDR.cpp, Line 2073
Start write address at LBA 0
DVD high compatibility mode: Yes
8:54:07 PM #24 Text 0 File Cdrdrv.cpp, Line 8128
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
8:54:53 PM #25 Text 0 File Cdrdrv.cpp, Line 1294
20:54:53.828 - SONY DVD RW DRU-710A\H1 T0 : Queue again later
8:58:43 PM #26 SCSI -1046 File Cdrdrv.cpp, Line 1442
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0C320000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x30
Sense Qual: 0x05
CDB Data: 0x2A 0x00 0x00 0x00 0x3C 0xE0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x02 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x30 0x05
8:58:43 PM #27 CDR -1046 File Writer.cpp, Line 304
Illegal disc
8:58:43 PM #28 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
8:58:43 PM #29 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
8:58:43 PM #30 Text 0 File DVDR.cpp, Line 2315
EndDAO: Last written address was 15583
8:58:43 PM #31 Phase 38 File APIProgress.cpp, Line 273
Burn process failed at 4x (5,540 KB/s)
8:58:43 PM #32 Text 0 File AudioCompilationImpl.cpp, Line 828
DRM: DRM burn session terminated.
8:58:43 PM #33 Text 0 File AudioCompilationImpl.cpp, Line 857
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=7.0.0.162 , size=24576 bytes, created 1/27/2004 3:32:00 PM
File 'Drivers\PXHELP20.SYS': Ver=2.03.18a, size=20576 bytes, created 6/9/2005 11:48:09 PM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
AML dvd media isn't the best dvd media to use. Try using better dvd media. Your SONY 710 drive is a REBADGED LITEON drive. LITEON drives tend to like DVD+R media than DVD-R. Check out the LITEON FORUM at CDFREAKS.COM.Recorder: SONY DVD RW DRU-710A, Media type: DVD-R
Disc Manufacturer: AML - -
it worked fine using that media before! could you reccomend a "good" media brand/type?
As I pointed out check out the LITEON FORUM at CDFREAKS.com.
As for dvd media try using FUJI 8x DVD-R that is manufactured by TAIYO YUDEN, look for the spindles that say MADE IN JAPAN. Or you could order the TAIYO YUDEN from www.rima.com. It's a known fact that LITEON dvd burners like yours tend to do better at burning DVD+R media. Download DVDINFO PRO or DVD IDENTIFIER to find out the media codes on blank dvd medai. Brand names don't mean much, it's the media codes that matter. -
cool thanks i already have DVD IDENTIFIER, and it says it a sony:
** INFO : Hex Dump Of 'Control Data Zone'-Block Listed Below
** INFO : 4-Byte Header Preceding 'CDZ'-Block Discarded
** INFO : Format 10h - Format Information Of Control Data Zone
0000 : 25 0f 02 00 00 03 00 00 00 26 12 7f 00 00 00 00 %........&......
** INFO : Hex Dump Of 'Media Code'-Block Listed Below
** INFO : 4-Byte Header Preceding 'Media Code'-Block Discarded
** INFO : Format 0Eh - Pre-Recorded Information In Lead-In
0000 : 01 40 80 12 23 00 52 00 02 85 0e 10 87 88 80 00 .@..#.R.........
0010 : 03 53 4f 4e 59 30 38 00 04 44 31 00 00 00 00 00 .SONY08..D1.....
0020 : 05 88 80 00 00 00 01 00 06 09 0c 12 a8 88 90 00 ................
0030 : 07 88 80 00 00 00 00 00 08 06 16 0a 0e 09 04 00 ................
0040 : 09 98 06 0c 0b 70 88 00 0a 80 00 00 00 00 10 00 .....p..........
0050 : 0b 08 16 18 97 88 75 00 0c b7 9b b8 83 00 30 00 ......u.......0.
0060 : 0d 0f ff d0 00 00 00 00 00 00 00 00 ............
ID is sony08d1, but i try some fuji!
sould i use fuji dvd+r? -
Yes you can try using FUJI 8x DVD+R, try to get the spindles that say MADE IN JAPAN.Originally Posted by blackevilsoul
...or use DVDDecrypter to burn. Much more reliable IMO.
/Mats
(1) Burn failed !!
By skinney6 in forum DVD RippingReplies: 13Last Post: 4th Feb 2010, 19:01 -
DVDfab failed initializing burn engine
By etlund99 in forum ComputerReplies: 0Last Post: 29th Jul 2009, 14:19 -
Seek Failed
By zeke1312 in forum Video ConversionReplies: 1Last Post: 20th Mar 2008, 07:59 -
New DVD writer... Burn process failed at 2x (2,770 KB/s)
By planetx in forum DVD & Blu-ray WritersReplies: 8Last Post: 8th Feb 2008, 16:40 -
mkv failed @ 90%
By joshmunkey in forum ffmpegX general discussionReplies: 2Last Post: 7th Nov 2007, 19:53
