Results 1 to 15 of 15
  1. Member ricardouk's Avatar
    Mar 2005
    Portugal
    Hi everyone
    a couple of days ago i downloaded divx6 and when i first used it it said i had to install a ac3 filter.
    i looked for one and installed it for divxconverter to work.
    the problem is that i unistalled divx6 and since then i am unable to listen to dvds with ac3 tracks. i unistalled the ac3 filter aswell but no ac3 still
    can anyone help me out?
    I love it when a plan comes together!
  2. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    What software are you using to play the dvds. Try media player classic which has its own AC3 decoder.
  3. Member ricardouk's Avatar
    Mar 2005
    Portugal
    im using powerdvd 6 the same one that i used to use before the problem appeared.
    i usede to get ac3 decoding with it before i installed the ac3 filter
    May 2001
    Just reinstall PowerDVD. It will correct everything.
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
  5. Member ricardouk's Avatar
    Mar 2005
    Portugal
    thanks for the info SLK.
    i tried to install powerdvd but it says that i must install directx 9 or above but i have directx9.c installed, dont know why it says that.
  6. Member ricardouk's Avatar
    Mar 2005
    Portugal
    anyone?
    May 2001
    Doesn't the PowerDVD installation disc contain the proper Directx files?
  8. Member ricardouk's Avatar
    Mar 2005
    Portugal
    i downloaded powerdvd from their site.
    May 2001
    The go to Microsoft and download the needed DirectX files - they're free.
  10. Member ricardouk's Avatar
    Mar 2005
    Portugal
    yea, but i already have directx9 or avove as requested by powerdvd. i have directx9.c.
    seems my only choice is to unistall it and install directx9 and then install direct9.c again.
    Slk can u recomend a dvd player? freeware if possible
    thanks
  11. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    is it looking for directX, or directX media components (not the same thing)
    Read my blog here.
  12. Member ricardouk's Avatar
    Mar 2005
    Portugal
    it says"you need directx9 or above"
    no reference about directx media in the warning
    May 2001
    Search your system for a program called "DXDIAG" and run it. On the first page, it shows the current version of DirectX installed. Verify that you really do have version 9.0c installed.
  14. Member ricardouk's Avatar
    Mar 2005
    Portugal
    ah ah
    it says directx versi0on is 4.09.00.0904
    and that the file at the bottom belongd to a previous instalation
