when i am tring to do dumax i saw that is the pgc there is two angle
what i need to do? to dumax both? or only one is good?
What program are you using? If you want a DVD with all the extras like more than one camera angle, that takes space. I generally dump the extra angles and most of the extras to get the most quality. Angle 1 is usually the default. If your really want the extras, you can put them on a second disc.
Just to add that angle one is your main movie and angle 2,3,4 etc is movie viewed from other angles that you can switch to if you want to view it that way.Sports events use that technique all the time for example on angles.
The second (third, forth etc) angles might also be alternate language sections (the opening crawl in the Star Wars DVDs was done with angles) or the director's cut of the film. If varies from disk to disk, and it can be too simplistic to simply take angle 1.
Read my blog here.
thanks you alll
if i have a disk of 4.7 giga with two angle(star wars) how can tell if it is other languge or diffrent camera?
and if i want to keep both angles in one dvd like what i have now in my dvd(star wars disk-4.7 giga) how can i do it?
Any Help With MKV and Angle Videos
By Endymion70 in forum EditingReplies: 0Last Post: 7th Jun 2010, 10:51 -
right angle SATA connectors
By rallynavvie in forum ComputerReplies: 22Last Post: 31st Aug 2009, 06:42 -
Angle trouble with AutoGK
By JBotAlan in forum DVD RippingReplies: 2Last Post: 9th Oct 2008, 23:55 -
2nd Angle plus subs?
By Jeikobu in forum MacReplies: 2Last Post: 18th Jul 2008, 08:25 -
Multi-Angle DVD-9 to Single-Angle DVD-5 help
By rayden54 in forum DVD RippingReplies: 6Last Post: 11th Sep 2007, 20:44
