I have been been burning for about 2 years now and i just recently have been having problems with nero. I know i can't fit the entire log here so i will post just the error. Hopefull it will be enough info for someone to find out what the problem is.
Line 813
[00:47:57] NeroVision Setup items (after recorder preparation)
[00:47:57] NeroVision 0: TRM_DATA_MODE1 (CTransferItem)
[00:47:57] NeroVision 2 indices, index0 (150) not provided
[00:47:57] NeroVision original disc pos #0 + 1744368 (1744368) = #1744368/387:38.18
[00:47:57] NeroVision relocatable, disc pos for caching/writing not required/required, no patch infos
[00:47:57] NeroVision -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1744368 blocks [SONY DVD RW DRU-710A ]
[00:47:57] NeroVision --------------------------------------------------------------
[00:47:57] NeroVision 12:42:29 AM #12 Text 0 File ThreadedTransferInterface.cpp, Line 984
[00:47:57] NeroVision Prepare recorder [SONY DVD RW DRU-710A ] for write in CUE-sheet-DAO
[00:47:57] NeroVision DAO infos:
[00:47:57] NeroVision ==========
[00:47:57] NeroVision MCN: ""
[00:47:57] NeroVision TOCType: 0x00; Session Closed, disc fixated
[00:47:57] NeroVision Tracks 1 to 1:
[00:47:57] NeroVision 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3572465664, ISRC ""
[00:47:57] NeroVision DAO layout:
[00:47:57] NeroVision ===========
[00:47:57] NeroVision __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
[00:47:57] NeroVision 0 | lead-in | 0 | 0x00 | 0x41
[00:47:57] NeroVision 0 | 1 | 0 | 0x00 | 0x41
[00:47:57] NeroVision 0 | 1 | 1 | 0x00 | 0x41
[00:47:57] NeroVision 1744368 | lead-out | 1 | 0x00 | 0x41
[00:47:57] NeroVision 12:42:33 AM #13 Phase 24 File APIProgress.cpp, Line 273
[00:47:57] NeroVision Caching of files started
[00:47:57] NeroVision 12:42:33 AM #14 Text 0 File Burncd.cpp, Line 4183
[00:47:57] NeroVision Cache writing successful.
[00:47:57] NeroVision 12:42:33 AM #15 Phase 25 File APIProgress.cpp, Line 273
[00:47:57] NeroVision Caching of files completed
[00:47:57] NeroVision 12:42:33 AM #16 Phase 36 File APIProgress.cpp, Line 273
[00:47:57] NeroVision Burn process started at 4x (5,540 KB/s)
[00:47:57] NeroVision 12:42:34 AM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2344
[00:47:57] NeroVision Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
[00:47:57] NeroVision 12:42:34 AM #18 Text 0 File DVDR.cpp, Line 1932
[00:47:57] NeroVision Recording mode: Sequential Recording Mode
[00:47:57] NeroVision 12:42:34 AM #19 Text 0 File Mmc.cpp, Line 20464
[00:47:57] NeroVision Set BUFE: Power-Burn -> ON , Generic write control : ON
[00:47:57] NeroVision 12:42:34 AM #20 Text 0 File DVDR.cpp, Line 2073
[00:47:57] NeroVision Start write address at LBA 0
[00:47:57] NeroVision DVD high compatibility mode: Yes
[00:47:57] NeroVision 12:42:34 AM #21 Text 0 File Cdrdrv.cpp, Line 8128
[00:47:57] NeroVision ---- DVD Structure: Physical Format Information (00h) ----
[00:47:57] NeroVision Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
[00:47:57] NeroVision Book Type: DVD-R (2), Part Version: 5
[00:47:57] NeroVision Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
[00:47:57] NeroVision Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
[00:47:57] NeroVision Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
[00:47:57] NeroVision Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
[00:47:57] NeroVision End Physical Sector Number of Data Area: 0 h
[00:47:57] NeroVision End Sector Number in Layer 0: 0 h
[00:47:57] NeroVision Data in Burst Cutting Area (BCA) does not exist
[00:47:57] NeroVision Start sector number of the current Border-Out: 0 h
[00:47:57] NeroVision Start sector number of the next Border-In: 0 h
[00:47:57] NeroVision Media Specific [16..63]:
[00:47:57] NeroVision 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
[00:47:57] NeroVision 12:43:29 AM #22 Text 0 File Cdrdrv.cpp, Line 1294
[00:47:57] NeroVision 00:43:29.171 - SONY DVD RW DRU-710A\H1 T0 : Queue again later
[00:47:57] NeroVision 12:47:13 AM #23 SCSI -1046 File Cdrdrv.cpp, Line 1442
[00:47:57] NeroVision SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x013C0000
[00:47:57] NeroVision Status: 0x04 (0x01, SCSI_ERR)
[00:47:57] NeroVision HA-Status 0x00 (0x00, OK)
[00:47:57] NeroVision TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
[00:47:57] NeroVision Sense Key: 0x02 (KEY_NOT_READY)
[00:47:57] NeroVision Sense Code: 0x30
[00:47:57] NeroVision Sense Qual: 0x05
[00:47:57] NeroVision CDB Data: 0x2A 0x00 0x00 0x00 0x03 0x60 0x00 0x00 0x20 0x00 0x00 0x00
[00:47:57] NeroVision Sense Data: 0x70 0x00 0x02 0x00 0x00 0x00 0x00 0x0A
[00:47:57] NeroVision 0x00 0x00 0x00 0x00 0x30 0x05
[00:47:57] NeroVision 12:47:13 AM #24 CDR -1046 File Writer.cpp, Line 304
[00:47:57] NeroVision Illegal disc
[00:47:57] NeroVision 12:47:13 AM #25 Text 0 File ThreadedTransfer.cpp, Line 229
[00:47:57] NeroVision all writers idle, stopping conversion
[00:47:57] NeroVision 12:47:13 AM #26 Text 0 File ThreadedTransfer.cpp, Line 223
[00:47:57] NeroVision conversion idle, stopping reader
[00:47:57] NeroVision 12:47:14 AM #27 Text 0 File DVDR.cpp, Line 2315
[00:47:57] NeroVision EndDAO: Last written address was 863
[00:47:57] NeroVision 12:47:14 AM #28 Phase 38 File APIProgress.cpp, Line 273
[00:47:57] NeroVision Burn process failed at 4x (5,540 KB/s)
[00:47:57] NeroVision 12:47:46 AM #29 SCSI -1033 File Cdrdrv.cpp, Line 1188
[00:47:57] NeroVision Sense Code: 0x04
[00:47:57] NeroVision Sense Qual: 0x01
[00:47:57] NeroVision CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[00:47:57] NeroVision 0x00 0x00 0x00 0x00 0x04 0x01
[00:47:57] NeroVision Existing drivers:
[00:47:57] NeroVision File 'Drivers\CDRALW2K.SYS': Ver=7.0.0.162 , size=24576 bytes, created 1/27/2004 3:32:00 PM
[00:47:57] NeroVision File 'Drivers\PXHELP20.SYS': Ver=2.03.18a, size=20576 bytes, created 6/9/2005 11:48:09 PM (Prassi/Veritas driver for win 2K)
[00:47:57] NeroVision Registry Keys:
[00:47:57] NeroVision HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
