I recently bought a JVC XV-NP10S DVD player and would appreciate some advice. I have a film that was burnt on to a Memorex DVD-R, I can play it on my computer's DVD player but not on my JVC. I copied the film on to a Sony DVD+RW and I can now play this new version my JVC. Why is this? The JVC manual says that I should be able to play DVD ±R/±RW. Should I avoid Memorex DVDs?
JVC XV-NP10S is decent player. I also recently purchased this player to replace my old first generation DivX player. It plays well DVD ±R and ±RW in my experience with. I did not notice yet any kind of flows, malfunctions or misbehaviors. I guess you have a bad media or possibly got a bad apple player. Bring it back to the store where you bought it for exchange. If the exchanged one will show the same symptoms, then it is a bad media for sure.
Playing External Subtitles with a Blu-Ray Disk????
By BlackDevil15 in forum Software PlayingReplies: 3Last Post: 30th Dec 2008, 11:44 -
help, Jvc hard disk camcorder GZ-MG255, the screen only comes out half.
By flowerhorn in forum Newbie / General discussionsReplies: 1Last Post: 28th May 2008, 11:26 -
Playing DVD-RAM Video Disk On PC
By Rayvyn007 in forum Software PlayingReplies: 2Last Post: 23rd Jan 2008, 14:01 -
Playing AVCHD DIsk
By nirbhayn in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 29th Oct 2007, 10:00 -
Format for recording, playing on different unit, then re-using disk ???
By TVTimeShifter in forum DVD & Blu-ray RecordersReplies: 16Last Post: 30th Sep 2007, 19:21
