I extracted a sound file from a movie,when i put it into different sound encoders they state that theres no audio file.If i play the file in windows media player it plays the sound fine.I used virtualdub mod to extract the sound from the movie.I then converted the movie using tmpgenc,but when i try to multiplex the movie and sound back together tmpgenc tells me that its a illegal mpeg file.What do i need to do to make this sound work with the movie?
Did you save it out as a WAV file with VDMod? If you just demuxed it, that can be a problem. What does VDMod say about the audio file?
sync sound from 1 file with video from another file
By solixxx in forum Newbie / General discussionsReplies: 9Last Post: 24th Sep 2011, 13:46 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
No Sound from MP4 file
By Alexstarfire in forum AudioReplies: 10Last Post: 18th Aug 2010, 04:59 -
Convert .mkv file to .ts file lost sound
By elmc in forum AudioReplies: 0Last Post: 19th Jul 2008, 04:30 -
Cleaning a sound file
By jimcgr in forum AudioReplies: 11Last Post: 2nd Jul 2007, 01:09
