Hi,
I would like to know how to rotate a video in Adobe Premiere Pro.
This function is easily available in Movie Maker ... so I think it shoul exist in Adobe !
Any idea ?
Hi, Carheim. I'm surprised no one has replied to you yet. I use Premiere Pro "Lite" AKA Premiere Elements, so the filters should be similar.
You can rotate a video in Video Effects ==> Distort ==> Transform ==> Rotation. If you need to rotate 90 degrees, just type in "90" in the appropriate place. I'm sitting here viewing a recent clip sideways. Works for me!
-- Ken -
Ken, that works great, but its work.
EVERY clip has "rotate" applied to it by default in Premiere pro!
With the clip highlighted,
JUST GO WINDOW>EFFECT CONTROLS>and expand
(the little trangle) next to "MOTION" on the efect controls window
THE FOURTH PARAMATER is ROTATION...adjust with wheel control or numerial entry here
any way Kens right too! Thats why we like premiere..lotta options! -
Right you are! Standard in every clip. I usually plumb the depths of my programs but the 'nooks and crannies' in these editors are cavernous! Thanks for info. -- Ken
Questions about using Adobe Premier Pro
By Graemey in forum Newbie / General discussionsReplies: 2Last Post: 21st Mar 2010, 07:02 -
not enough disk space - Adobe premier Pro 2.0
By Reggie6966 in forum Newbie / General discussionsReplies: 11Last Post: 8th Nov 2009, 04:07 -
Adobe Premier Pro to dvd
By tat2loo in forum Newbie / General discussionsReplies: 7Last Post: 29th Apr 2008, 13:57 -
Adobe Premier Pro - Mpg - Skipping.
By primalmedia in forum EditingReplies: 1Last Post: 7th Nov 2007, 11:35 -
5.1 AC3 and DTS in Adobe Premier Pro
By zerohash in forum Authoring (DVD)Replies: 6Last Post: 25th Sep 2007, 08:39
