    Jul 2004
    Philadelphia, Pa, USA
    Hello.
    I was doing a project involving a video game. So, I connected my PS2 to my VCR and recorded onto VHS. I then connected the VHS Player to the ATI TV Wonder Pro, and the end result is the audio is too low.
    Is there a way to fix this?
    Any help is greatly appreciated.
    Sincerely,
    John Shumate - Owner of High Tech Entertainment
    www.hteradio.net & www.hteradio.org
  2. Member lumis's Avatar
    Jan 2005
    the remnants of pangea
    go to volume control (the little speaker icon in the system tray), click options, properties, put the dot next to recording, make sure "line-in" is checked, click OK, put a check in the "line-in" box, adjust the volume, do a few test recordings until you find the desired volume level.
    Apr 2005
    United States of America
    Which program are you using to capture? There is usually an audio setting in the program you are using. I reccommend VirtualVCR.
    Jul 2004
    I'll try thr line in setting.
    Also, I'm using the Capture Software that came with the card.
    Its pretty good.
    I seem to cant get virtual VCR to work with it.
    Sincerely,
    Apr 2005
    I have the same card you have, and VirtualVCR works just fine =) What exactly isn't working?
    Jul 2004
    Ok..I got it to work.
    I have a question:
    Also, how do I make it capture to MPEG 1 or MPEG 2 format?
    Sincerely,
    Apr 2005
    It only captures AVI -- capture AVI and then convert to MPEG-1/2.
