hi i am trying to put some music i have with a video i have using tmpgencs dvd author and i get this message when i try to put the audio in ok
Illegal audio format.
For a standard DVD you can only use the following audio formats:
Dolby Digital (AC-3), MPEG-1 Audio Layer-2, or Linear PCM.
does any one know what is wrong at all or how i can fix the problem any help would be very much appreciated thanks everybody
bye
from phillip cole email phillbrett68@optusnet.com.au
I would take the original file and run it through AVIcodec or Gspot and see what it says about the audio. If it's a AVI, it could be MP3 VBR audio or AC3 audio that TMPGEnc Author can choke on. If it's an AVI, maybe use VirtualDub or MOD and save out the audio as a WAV, then encode that as AC3 with ffmpegGUI or similar. Or just encode the audio with TMPGEnc encoder to MPEG-1 Layer2. Then feed this into TDA. Or it could be the audio is out of spec for DVD. Either way AVIcodec or Gspot should tell you. Also check the DVD spec (To the left 'What is DVD' <<<) to see what's required.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
