Sorry if this has been asked already (I really couldnt find this w/ a search) but I need help in putting a movie called “Bronx Tale” which is in mpeg-3 into a DVD+RW so I can play it into my standalone DVD player. The movie is 1 hr and 59 minutes long and is 750mb
I have easy CD creator which has a program called DVD builder where I imported the movie. I tried to burn the movie and it worked but when I played it on my dvd player there was a lot of skipping of the audio.
can i get some help?
Try authoring with TMPGEnc DVD Author .It is a very reliable program.Also make sure you dont burn the DVD-RW at too high a speed.
When you say MPEG-3 do really mean MPEG2? -
Originally Posted by laspis59
i tired using tmpgenc dvd author and it said i can only burn mpeg 1 and 2. I guess i have to convert it from mpeg-3 to mpeg-2. Which program would convert it?
also i looked at the properties of the file and under video compression it said divx codec. Im confused now
Skipping audio problem!
By heffneil in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 21st Mar 2011, 12:02 -
WD TV USB Player 5.1 Audio Skipping
By njsges in forum DVD & Blu-ray PlayersReplies: 3Last Post: 23rd Jan 2009, 03:31 -
MEncoder skipping frame with audio conversion
By Towin in forum Video ConversionReplies: 2Last Post: 24th Mar 2008, 12:08 -
Matroska Video - Audio delay when skipping
By strutter_uk in forum Newbie / General discussionsReplies: 2Last Post: 15th Jan 2008, 12:08 -
audio skipping on video capture
By wan2no in forum Newbie / General discussionsReplies: 3Last Post: 26th Jul 2007, 19:18
