Hello I am trying to figure out a couple of problems that i always with svcd2dvd. One of the problems I have is that the words go out of sync with the movie. If that is not the problem then it is usually the movie goiung in slow motion like frame by frame. I am not saying that every single time one of these things happen but it happens more times than none. I would also like to add that when i watch them on my apex dvd player they almost always play fine because it is vcd compatable but when they are watched on any other dvd player( playstation 2, pioneer, ext.) is when I always have the problem. Any help would be thankful
Results 1 to 12 of 12
What version are you using? CAn you send a log of such an run?
Logs are in the log folder under the location where you installed svcd2dd.
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Name: SVCD2DVD 2.0 RC9b
Title: 2.0 RC9b
Version: 2.0.1955.34597
Executable: E:\Program Files\Svcd2Dvd\SVCD2DVD.exe
Executable size: 2.25 MB
Executable size in bytes: 2367571
Executable CreationTime: 5/10/2005 12:14:50 AM
Executable LastWriteTime: 5/22/2005 11:04:31 PM
Executable LastAccessTime: 6/9/2005 9:23:00 PM
************************* Operating System *************************
Operating System: Microsoft Windows XP Home Edition
Service Pack: Service Pack 2
Version : 5.1.2600
Windows Directory : C:\WINDOWS
OSLanguage: 1033
CodeSet: 1252
CountryCode: 1
Local: 0409
Total Physical Memory: 503 MB
Free Physical Memory: 219 MB
Total Virtual Memory: 1.99 GB
Free Virtual Memory: 1.96 GB
***************************** Computer *****************************
Computer Manufacturer Name: Sony Corporation
Computer Model: PCV-RS100(UC)
System Type: X86-based PC
Computer Name: HOME
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 1
User Name: HOME\Jason
***************************** Processor ****************************
Manufacturer: GenuineIntel
Processor: Intel(R) Pentium(R) 4 CPU 2.00GHz
Description: x86 Family 15 Model 2 Stepping 4
CPU Speed: 2.02GHz
CPU FSB: 100MHz
L2 Cache Size: 0 bytes
***************************** Time Zone ****************************
Time Zone: (GMT-05:00) Eastern Time (US & Canada)
****************************** VIDEO *******************************
Name: Intel(R) Extreme Graphics Controller
Processor: Intel(R) 82845G/GL Chip
Mode: 1024 x 768 x 4294967296 colors
Video Ram: 64.0 MB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 9.19 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 62.5 GB
DeviceID: E:
FileSystem: NTFS
FreeSpace: 12.9 GB
********************* END OF SYSTEM INFORMATION ********************
Processing assets for DVD creation
Processing cobra-cm1.mpg
17:27:13: ffmpeg version 0.4.9-pre1, build 4754, Copyright (c) 2000-2004 Fabrice Bellard
17:27:13: configuration: --disable-debug --enable-a52 --enable-gpl --enable-memalign-hack
17:27:13: built on May 5 2005 19:13:42, gcc: 3.2.3 (mingw special 20030504-1)
17:27:13: Input #0, mpeg, from 'E:\Program Files\shared\cobra-cm1.mpg':
17:27:13: Duration: 01:08:24.4, start: 0.339000, bitrate: 1582 kb/s
17:27:13: Stream #0.0: Video: mpeg1video, yuv420p, 352x240, 29.97 fps, 1150 kb/s
17:27:13: Output #0, dvd, to 'E:\Program Files\shared\cobra-cm1_S2D.mpg':
17:27:13: Stream #0.0: Video: mpeg1video, 352x240, 29.97 fps, q=2-31, 1150 kb/s
17:27:13: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
17:27:13: Stream mapping:
17:27:13: Stream #0.0 -> #0.0
17:27:13: Stream #0.1 -> #0.1
17:33:01: video:576185kB audio:224466kB global headers:0kB muxing overhead 3.759895%
Processing cobra-cm2.mpg
17:33:04: ffmpeg version 0.4.9-pre1, build 4754, Copyright (c) 2000-2004 Fabrice Bellard
17:33:04: configuration: --disable-debug --enable-a52 --enable-gpl --enable-memalign-hack
17:33:04: built on May 5 2005 19:13:42, gcc: 3.2.3 (mingw special 20030504-1)
17:33:04: Input #0, mpeg, from 'E:\Program Files\shared\cobra-cm2.mpg':
17:33:04: Duration: 01:08:24.1, start: 0.339000, bitrate: 1582 kb/s
17:33:04: Stream #0.0: Video: mpeg1video, yuv420p, 352x240, 29.97 fps, 1150 kb/s
17:33:04: Output #0, dvd, to 'E:\Program Files\shared\cobra-cm2_S2D.mpg':
17:33:04: Stream #0.0: Video: mpeg1video, 352x240, 29.97 fps, q=2-31, 1150 kb/s
17:33:04: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
17:33:04: Stream mapping:
17:33:04: Stream #0.0 -> #0.0
17:33:04: Stream #0.1 -> #0.1
17:39:04: Done: Processing assets for DVD creation
Authoring DVD Folders
17:39:04: video:576164kB audio:224450kB global headers:0kB muxing overhead 3.786627%
17:39:04: Creating TitleSet # 1
17:39:04: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
17:39:04: -->: DVDFolders creating VTS
17:39:04: -->: VTS 01
17:39:04:
DVD Folders: Processing E:\Program Files\shared\cobra-cm1_S2D.mpg...
17:39:42:
DVD Folders: Processing E:\Program Files\shared\cobra-cm2_S2D.mpg...
17:40:15:
17:42:23:
17:42:23: Finalising DVD...
17:42:23: SVCD2DVD: DVDfolders
17:42:23: -->: DVDFolders creating table of contents
17:42:23: scanning D:\Movies\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
17:42:23: Finalising DVD...Done
17:42:23: Done: Authoring DVD Folders -
Does that one do the slow motion thing? Can you update to the latest version? That build is not the latest.
no this one is one of the one that the lips go out of sync. would you like me to post one that goes frame by frame? What do you mean by later version I thought v2 9b was the latest
ok. Are the orignal mpgs in sync? RC9b is the latest but there was a small update.
Ok. Can you send the second mpg to my ftp for investigation?
ftp://BetaTester:badger@ftp.svcd2dvdmpg.com:7676/jlemon42779/SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
i dont have the mpgs anymore i erased it when i put it on disc. i have others i will review and then send one that is messed up to you
Video Run Time Gets Cut in half - and other conversion problems...
By scotsgael in forum ffmpegX general discussionReplies: 0Last Post: 3rd May 2010, 01:41 -
problems with avc to mpeg-2 in tmpgenc xpress 4.0 - more than 3x run time?
By NoFace in forum Video ConversionReplies: 3Last Post: 18th May 2008, 21:01 -
Long time burning and skipping problems
By championjosh in forum DVD & Blu-ray WritersReplies: 8Last Post: 16th Feb 2008, 01:11 -
First time copying a DVD, encountering problems with subtitles.
By Mrs Chippy in forum Newbie / General discussionsReplies: 11Last Post: 23rd Oct 2007, 10:48 -
Time sync problems.
By Poppa_Meth in forum ComputerReplies: 9Last Post: 1st Sep 2007, 00:30
