Hi all
i am quite a noob in DVD.
Is there any free software you could use to do up a dvd menu and link it to 2 ISO dvd file?
Since 2 iso extract to the same directory, how do i do to burn both into a dvd with a menu link to each different movie?
Assuming that your 2 iso's will fit on one DVD...
You need to extract the files from your iso's and then re-author in order to create a menu, you cannot burn them directly.
Isobuster (free) will extract, TMPGEnc DVD Author (free trial) will accept the DVD files (add DVD video) as input."Art is making something out of nothing and selling it." - Frank Zappa
Creating a DVD with menu with several ISO files
By SandraKlim in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2011, 13:00 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 14:46 -
GUI for DVDAuthor burning iso to dvd player no menu audio
By opti280 in forum Authoring (DVD)Replies: 13Last Post: 8th May 2008, 20:11 -
DVD from ISO has no audio (except menu does)
By KraftDinner in forum Authoring (DVD)Replies: 3Last Post: 30th Dec 2007, 18:53 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19
