I got my dad a new samsung DVD player and it supports 10 types of flash memory cards. I was thinking you think its possible to put DVD on a memory card then insert and play ? this way instead of buring up all my DVDs i could hold files on PC and then transfer/delete them as needed ? Just curious, i cant try anything till fathers day , haha
Results 1 to 9 of 9
The Lexar 8GB card goes for about $1000US. But I have used Xvid formats to crunch a DVD down to about 250MB and put it on a Compact Flash card for use on a pocket PC. On that small of screen, quality is watchable.
Probably in a very few years a flash card in the 5-8GB range will be cheap enough to be useful in a DV camera even as a tape replacement.
Even now a 1GB card will hold a DVD length VCD quality video that would possibly play on your DVD player, though I think that player may use the card slots only for showing slide shows from a still camera flash card. -
Never knew memory cards can hold up to 8GB. I heard of 1 GB. Nevertheless, its still expensive as redwudz has pointed out.
The cost doesn't justify it. -
waheed, I bought a '2GB flash card', Sony brand, from Staples a few months ago. Turned out to be a subminiature hard drive. Apparently I didn't read the fine print.
Works fine for the price ($60US) but I don't dare drop it on the floor like I could a solid state flash card. I have ran two of my flash drives through the washing machine and dryer with no ill effects, though I don't recommend this type of 'cleaning'.
Imagine a +20GB flash card. Maybe not so far away. -
They have microdrives, and they have non-drive compactflash too. Up to 1GB for the non-drive ones, last I saw.
KISS me ... creating a playable on stand alone DVD player DVD
By bdaul in forum MacReplies: 7Last Post: 28th Mar 2010, 06:55 -
stand alone dvd player and mpeg2 files
By sportflyer in forum Newbie / General discussionsReplies: 7Last Post: 17th Feb 2010, 08:34 -
First Stand Alone RM/RMVB DVD Player
By sushix in forum DVD & Blu-ray PlayersReplies: 13Last Post: 7th Jun 2009, 02:42 -
Stand-Alone DVD Player recommendation
By -mm- in forum DVD & Blu-ray PlayersReplies: 24Last Post: 2nd May 2008, 13:13 -
Can you burn Xvid files to DVD so they will play on stand alone DVD Player?
By JoeBolden in forum Newbie / General discussionsReplies: 4Last Post: 3rd Aug 2007, 17:48
