(I posted this in another forum accidentally)
Hi.. I have a situation where I used DVDShrink to rip and compress a bunch of episodes off of the 2 discs of a season DVD so that I could have one disc with all of the episodes.
I used TMPGEnc to author the DVD.. combined all the episodes, created the menu, etc. I selected the option for firstplay to go directly to the menu.
Now, when I put the DVD in the first time, it's great.. goes to the menu where I can select an episode and play it. But, I can't then get back to the menu. Hitting the menu button on the remote does nothing... the menu refuses to come up.. if I want the menu back, I have to take the DVD out of the player and put it back in.
Anyone know what's going on and how I can fix this?
Thanks!
Have you chosen "Display Main Menu" for the option "Action to take after each track has been played"
Edit:It probably makes no difference
TMPGEnc AW 4: just 1 menu for chapters in different tracks
By reini in forum Authoring (DVD)Replies: 4Last Post: 25th Mar 2009, 06:17 -
TMPGEnc 3 - Quick Menu Question
By heyjjjaded in forum Authoring (DVD)Replies: 1Last Post: 17th Aug 2008, 15:05 -
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 20:20 -
TmpgEnc Menu Confusion
By marioval in forum Authoring (DVD)Replies: 6Last Post: 12th Oct 2007, 07:23 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 20:43
