  1. Alright I wasn't sure which forum to post in so I figured I'd post in this one
    I use Tmpgenc Dvd Author 1.6 to author and Nero 6.6 to burn. I have 2 dvd one is the Tatung dv-688 ( won't find it on this site, but found it somewhere that it only has dvd+R capbilties. ) and the other is Toshiba something ( can't remember the # but when i looked it up it said that it has dvd-r capabilties ). Anyways after I author my dvds and burn it with a dvd+r (dvd-video btw) and pop it in the Tatung player, it works fine ( media used is Benq, Maxell and Fuji all +R ) then I tried it in the Toshiba which gave me a disc error and I thought that it made sense since it said that only -R would play. So then I burn an other copy using a Memorex -R and tried that in the Toshiba and still didn't work, tried the same -R in the Tatung player and got a disc error as well, the disc worked fine tho on the comp as I expected it to. I thought it might be media so I just gave up on the -R for a while and just stuck with using +R and using my Tatung player to play. Then I found this cheap generic disc lying around with contents burnt on it, tested it with Disc Identifier and turns out it was a -R disc, figured I'd put it in the dvd players and see if it would work and suprisingly it worked on BOTH players. Any idea why cheap disc worked ? Could it be the authoring or what ?
    Thanks for any help.[/b]
  2. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    There's no such thing as universal compatibilty when it comes to DVD-/+R. Some machines play everything, some play none. For example, my Pioneer players play everything with no problem, while my flatmate's Panasonic chokes on +R. Check the media section of this site for more about the players and discs you use.
    You are in breach of the forum rules and are being banned. Keep your opinions to yourself.
    / Moderator John Q. Publik
  3. Well I looked up the Toshiba model and it said that it should play the memorex -r that I threw in, but it didnt. Maybe its the authoring ?
