  1. This is getting bad now..
    Its been about a month, and I still can't fix it?
    I converted a avi to DVD using vdub for sound then Tmgnec for decoding , then tmg auther as always but the sound is about 2 seconds before action.
    and the avi works fine before decoding.
    I did a serch on multiplexing and so on, and I still don't get it.
    The only thing I did was that works with shit qulity is using win avi, which converts it in about 10 minutes but its super crap qulity.
    Please if any one of you can take the time and walk me through how to fix this?
    Apr 2004
    Miskatonic U
    If you wan't it fast, try DivxtoDVD. The quality is as good as the source, and it's fast.
    If you want it to look as good as it can, then use virtualdub to save the audio off to uncompressed wav (you must be in full processing mode to do this, expect around 900mb for 90 minutes, give or take). Load the video into tmpgenc, and replace the audio with the wav file.
    If the audio is out by the same amount the whole way through, then you have a delay problem which can be fixed either in virtualdub before you save the audio out, or by one of the delay tools in the audio section of Tools (to your left)
    Read my blog here.
  3. is there a guide or something to fix the delay in vdub?
    Please help me man..
    You said theres a program in Vdub to fix this in tools but theres so many in vdub.
    What am I looking for?
    Help please
  4. Member thecrock's Avatar
    May 2005
    england
    “He who makes a beast of himself gets rid of the pain of being a man.”
