Very new to DVD burning/authoring so bare with me please
Ok here is what I got going on:
I have downloaded many DivX encoded files that total up to around 11 GB and I wish to put them into some playable form to watch in my DVD Player.
I have tried to use TMPGEnc to convert to MPEG so that I can author the DVD that way but then my 11 GB's is going to turn into much much more. Is there any way to author a DVD with menus in the DivX format that I have now that will keep things at 11 GB's so I can use a couple of DVD's?
If this question is widely known sorry for the ignorance but I really have done quite a bit of searching for this problem.
THANKS ALOT
Results 1 to 9 of 9
Yep, I believe DXN have setup a new certification program. As soon as you see a DivX Ultra certified player you will know that menu support is here.
Still currently you get a file browser to select what to play. -
No but I am currentyl looking into buying the Philips 642 which does support DivX. Will I be able to create DivX DVD's with menus on that or no?
Second Question:
What is the best way to burn a DVD with menus from movies in DivX? I have 5 seasons worth of a TV Show in DivX and TMPGEnc I know converts to MPEG but the problem is with so many DivX files it turns into alot of DVD's. Any way to convert them to mpeg without increasing the size so much? (It is a cartoon so some quality lost isnt the biggest issue to me) -
My alternate solution is to send a/v signal from a computer to the tv (wired/wireless). That way, you can play whatever file formats on tv without the fuss of converting them or moving them around from media to media. A wireless av sending / receiving unit costs just under $100 US, comparable price to a divx player.
That wireless idea sounds like the best till they come out with a DivX Ultra player, can you recommend any good brands that wont cause any interference with my wireless router?
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 13:00 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 12:00 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 05:48 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 10:24
