  1. hrm....does dvd2avi indicate somewhere how outta sync the audio is, if that should happen?
  2. i thought i saw it in another post, but i don't quite remember. can someone please elaborate?
    Jul 2001
    Anchorage, AK, USA
    Perhaps in the name of the audio file it creates? I noticed an "18ms" in there.
  4. yep, it's shown in the filename of the demuxed audio
  5. can one of you guys post the filename of the .wav file dvd2avi extracted with that outta sync time in it?
  6. o..and i forgot, i'm using one of the older versions of dvd2avi.....could it be that only the later versions of dvd2avi indicates how outta sync the audio is in the filename?
  7. I really don't know if it does it for decoded audio, I think it may only be if you Demux, and I'd really suggest upgrading
  8. thnx for the suggestion Shabubu, any reason y i should upgrade? upgrades tends to have bad results for me when the earlier versions seem to be working fine.
    i.e. earlier smartripper versions don't use aspi, but the later one's do and even with force aspie, the new smartrippers don't work
