hi,
Im trying to convert avi to dvd pal using mainconcept encoder 1.4.2
What i want to know is how to determine if a movie can beable to view in 4:3 fullscreen instead of 16:9 with out it looking swashed.
Is there a program that can tell me which aspect would suit my films?
Also is there a program that coverts dvd compliant mpegs to vobs,i know dvdlab does , any other?
thx
You should be able to tell simply by looking at it.
Any authoring app should be able to, although some may require that you demultiplex first. -
I dont understand how can i tell?
Does demultiplex mean elementry video and audio ,mpv file and mpg?
If it is mainconcept can do that.
So name me some apps that can covert them to vob and easy to use ofcourse
What aspect ratio is the AVI ? (Divide the width by the height). If you get less than 1.78 then you need to go 4:3, and add black bars. If it more than or equal to 1.78 then you can go 16:9. You may still have to add black bars, and you will have to resize more carefully to get it right.
Read my blog here.
Hi, ron12347
If you open your .avi in VirtualDubMod, and go to File>File Information, then you can get an exact aspect ratio in the form of w x h.
Thanks.
aspect ratio
By devdev in forum Video ConversionReplies: 5Last Post: 19th Apr 2012, 18:31 -
Aspect Ratio
By ping182nz7 in forum EditingReplies: 12Last Post: 26th Apr 2010, 14:30 -
Aspect Ratio
By jackowens in forum Video ConversionReplies: 2Last Post: 18th Mar 2009, 18:40 -
16:10 Aspect Ratio
By SWBisbee in forum Newbie / General discussionsReplies: 4Last Post: 31st May 2008, 02:41 -
what is aspect ratio?
By mai_hnf in forum Authoring (VCD/SVCD)Replies: 3Last Post: 29th Sep 2007, 23:29
