I have tried to convert DV captured AVI file with CCE but the results were some green color on the screen...is there any settings to avoid this green color?
I am not a DV expert but since you have had no reply for some time, I will give it a go.
DV files are of two types, Type 1 and 2. I think CCE will only accept one of the two types. There are tools that supposedly can convert DV from one type to another.
I know this is a long shot, but if you have not solved the issue, perhaps it's worth checking this too.The more I learn, the more I come to realize how little it is I know. -
I routinely convert DV type 2 to compliant mpeg2 using CCE Basic. I have not observed any color issues. I pretty much use the default settings for DVD except that I set quantization to 24 instead of 16.
There is a free software app on the Canopus website that will convert DV
Type 1 to Type 2 if that is what you find is the problem.bits
Captured AVI file too large
By drgt in forum Newbie / General discussionsReplies: 38Last Post: 29th Sep 2010, 08:22 -
Ive captured a good lossless AVI file, now what!
By Darkstraw in forum Video ConversionReplies: 3Last Post: 12th Aug 2008, 01:10 -
faint audio on captured .avi file
By coastie in forum AudioReplies: 1Last Post: 27th May 2008, 06:54 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 21:27 -
Help With Premiere Pro 2 (importing Screen Captured Avi File)
By paulinnorway in forum EditingReplies: 2Last Post: 15th Oct 2007, 11:19
