I'm using DvdShrink to shrink my backups then having it create an ISO file and when done automatically opening Dvd Decrypter so I'm ready to burn. Since DvdShrink is creating the ISO file when is Dvd Decrypter actually decrypting the file, as soon as the file appears (in Decrypter) or is it doing it during the burning process?
Also some people use Dvd Decrypter first to write the file then use DvdShrink, is there an advantage to this? What would the settings and procedure be to this?
Results 1 to 12 of 12
DVDShrink also decrypts....DVDDecrypter cannot shink. DVDDecrypter is a better decrypter....especially for stubborn discs.
DVDShrink cannot burn(on its own).
Using DVDDecrypter first?....6 of one...half dozen of the other. Usually people only do that with above mentioned stubborn discs. -
DVD Decrypter has better ripping potentials like ripping sony arrcoss protection which dvd shrink cannot handle.
So you're saying when you use Shrink then Decrypter like I'm doing then Shrink is doing all the decrypting and Decrypter is only being used for burning, I didn't know that. I guess I thought all Shrink did was shrink and remove Region protection, I learn something every day.
So if I ever get an error using Shrink then I should start all over and begin writing an ISO within Decrypter and when done open Shrink and "Open Files"? Where should the ISO file be located and how do I get the decrypted ISO file back to Decrypter so I can burn? -
What I do is rip using DVD Decrypter in file mode. You can direct DVD Decrypter to put them where you want them on your harddrive. I then open up the ripped files in DVD Shrink. Just Open DVD from folder in Shrink and browse to where you've ripped the files. Shrink and output to an ISO file as you normally do. Then burn the resulting ISO using DVD Decrypter.Originally Posted by mccoady
And if you haven't already heard, DVDDecrypter is now officially out of development - lightningUK! has been ordered to shut down. Watch out for an imposter site with the username lightningUK!! (double exclamation). It is a phony site.
Thanks guys! I think it's funny though since I have apparently been using Shrink to decrypt my files (which I didn't know) instead of Decrypter that I've never ran into any problems where Shrink couldn't decrypt. I was under the impression that it had to be updated fairly often and if I'm not mistaken Shrink hasn't been for awhile.
I believe I read when Decrypter is outdated, Ollie said Decrypter could be configured so it still could be used with AnyDvd. So at that point what would be the procedure to shrink, decrypt, make ISO file and burn, could you still use Shrink first and make ISO file and in turn open Decrypter to burn since AnyDvd would be running in the background doing the decrypting? In other words the way I have been doing it except I would have AnyDvd running in the background. -
Once you successfully start using DVDShrink the files are decrypted. It appears that you're only using DVD Decryptor to burn the ISO file produced by DVDShrink, which is decrypted. SO don't need (and will never need) AnyDVD running just to burn the ISO with DVD Decryptor.Originally Posted by mccoady
The time that you may need AnyDVD is if you encounter a DVD that DVDShrink AND DVD Decryptor cannot decrypt. Until then, keep doing what you're doing if you're happy with the results. -
Just curious but I've read where some people think that the job DvdShrink does shrinking a disc is unacceptable as far as the amount of compression it uses, is there another program that works better that is just as simple to use? By the way I use Shrink with it set to "Auto" and for the most part think that it does a pretty good job and I do prefer to work with ISO files because with my limited understanding of using these programs, all I have to do is create one (ISO file) and burn.
NERO RECODE is a great alternative - Fast...
"Quit Playing With The Clock..."
Rudy - Funhouse pinball game -
DVDdecrypter/DVDFabDecrypter + DVDRebuilder+ CCE > DVDdecrypter/DVDFabDecrypter + DVDshrink...
dvd decrypter
By dr strange in forum Newbie / General discussionsReplies: 5Last Post: 27th Jan 2009, 15:11 -
DVD Decrypter from one pc to another
By jwedge in forum ComputerReplies: 3Last Post: 27th Jan 2008, 00:35 -
DVD Decrypter
By Beaker14 in forum Newbie / General discussionsReplies: 17Last Post: 26th Oct 2007, 23:39 -
I am using DVD Decrypter
By Lissettep in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Oct 2007, 17:55 -
DVD Decrypter wont work with my external drives?
By dazza555 in forum DVD RippingReplies: 4Last Post: 23rd Jun 2007, 20:04
