Guys, I recently installed a prog that required me to install Java Sun. Every since I installed Java, I've been getting infected with java exploits.
For those of you that have Java Sun installed and don't constantly get infected with these exploits, will you please let me know what it is that you're doing. Is there some kind of setting within Java that will correct this flaw? Although My real time protection picks them up, they are really annoying.
Get rid of it. I had the same problems. It bypasses your security settings also. If you select to prompt for scripting or not use scripting it will run anyway. Scripting is how 95% of all security breeches are made.
I like your style! (Look in your taskbar)
Good eye cobra that's hilarious. P0RNSTARS TO DOW...Originally Posted by Cobra
SRT exploit?
By drgt in forum Newbie / General discussionsReplies: 10Last Post: 7th Oct 2010, 11:10 -
Windows XP zero-day Exploit
By Poppa_Meth in forum ComputerReplies: 6Last Post: 16th Jun 2010, 14:46 -
ProjectX Java error
By kimse in forum EditingReplies: 8Last Post: 14th Sep 2008, 16:44 -
Java
By Lucifers_Ghost in forum ComputerReplies: 2Last Post: 1st Jun 2007, 09:27
