OK, I have used this process many times with great results. For some reason, this particular MPEG is giving me issues. I'll describe my process:
I am converting sporting events to DVD. I first convert from VCR to my stand-alone DVD recorder. I typically use 3 DVD-RW's to convert a game (usually football). I then rip the 3 DVD-RW's to my PC into 3 seperate .vob files, one for each DVD-RW using DVD Decryptor. Then, I use MPEG2VCR to edit and create 2 seperate MPEG files, for each half of the game. I import the MPEG into Adobe Encoreand create menu. Then, I create a DVD folder, then use DVD Shrink to skrink and burn the DVD with Decryptor again.
No problems with this process. However, with this one particular MPEG, Encore wants to encode it before it creates the DVD folder. When I try to select "Don't Transcode", it is greyed out.
Any ideas? Again, this process has worked many times before.
Thanks for the help, guys!
Closed Thread
Maybe your video is not the anal 720x480 spec it requires. Adobe Encore is really crappy for this reason, it does NOT support the full DVD spec, just a small infintesimal little sliver of it.
continue https://www.videohelp.com/forum/viewtopic.php?t=271696 . please donnn't cross post.
Encore CS4 "End of file" error
By docfo4r in forum Authoring (DVD)Replies: 1Last Post: 31st Jul 2013, 02:57 -
ffmpeg can transcode both audios on "dual avi"?
By CactusMan in forum Newbie / General discussionsReplies: 3Last Post: 12th Jan 2012, 07:25 -
Why don't you need special "accurate" ripping programs to copy DVDs?
By sldvd in forum Newbie / General discussionsReplies: 6Last Post: 15th Aug 2010, 05:30 -
U.K. to give new meaning to "Big Brother" is watching
By aedipuss in forum ComputerReplies: 11Last Post: 18th Oct 2008, 09:00 -
API "SetParent" in VB6: Function & Ctrl keys don't work
By gll99 in forum ProgrammingReplies: 4Last Post: 9th Mar 2008, 19:37
