Hi, I have an .avi which has picture when played in WMP10 but no sound, when directed to the WMP site it cannot find the audio codec and says that I may find one searching the web for ""FF" (this is the WaveFormat or FourCC identifier of the codec)" I did a codec check using AVIcodec and it says for the audio " 0xFF = Unknown, Unsupported" how do I work out what audio codec I need? any help much apreciated.
Zetor
Can media player classic play it?
What does GSpot have to say about the audio codec?
(That WMP refuses to play something shouldn't come as a big surprise...
/Mats -
Media Player Classic should play it fine since it has a built in aac decoder.
For wmp you need something like ffdshow or coreaac. -
I don't have WMP Classic to try it but I did run Gspot on it and it gave the same results: Name:0x00ff: <unknown> Bitrate: 132 kb/s (66/ch, stereo)
Fs: 48000 Hz The Render info said: " DirectShow partially succeeded to play file. The actual text of the error or warning is:
0x00040242: VFW_S_PARTIAL_RENDER - Some of the streams in this movie are in an unsupported format. "
I tried to transcode it using Divx toDVD and it wouldn't, I burnt it to DVD-Video using Nero VE3 and it played fine but without sound.
Zetor -
I'm confident celtic_druid knows what he's talking about. Follow his suggestion. I don't think it will make any difference what encoder you try. If you don't have the codec - you dont!
Media Player Classic is free. Try it.
/Mats -
I just played the avi in media player classic and the sound worked, thanks for the info, I'm still not sure how I can transcode it to burn to DVD-Video and keep the sound, is it going to be possible to do this?
Zetor -
AVI - No sound on PS3
By tehkimsta in forum AudioReplies: 2Last Post: 14th Apr 2011, 20:48 -
Vob to avi, NO SOUND
By pekkaaa in forum ffmpegX general discussionReplies: 1Last Post: 24th Dec 2009, 12:10 -
.mov to .avi with sound
By siobhan in forum ffmpegX general discussionReplies: 2Last Post: 2nd Jul 2008, 00:25 -
no sound for avi
By kangaris in forum EditingReplies: 5Last Post: 22nd Sep 2007, 06:26 -
AVI - sound with VLC , no sound Toast burned
By BattyRoy in forum MacReplies: 15Last Post: 27th Jul 2007, 20:21
