Well, I've previewed it again, and it looks like it's going to work. I may have done something wrong earlier.
Results 61 to 65 of 65
So how do I fix it?Originally Posted by terryj
This is what I got, by the way:
Encoding started on Sun Jul 10 20:26:58 EDT 2005
/Users/mikecairns/Desktop/movie.avi.ff/
-f 5 -b 3742 -q 3 -B 260 -V 230 -a 3
-F 4
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
MPlayer dev-CVS-050123-19:55-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
CommandLine: '-noframedrop' '-vo' 'yuv4mpeg' '-ao' 'pcm:waveheader' '-v' '- -
Give me the next thirteen lines, specifically up
to the part where it says it is reading the codecs
within your file... anything also within brackets will also
be helpful."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
I just did a "select all". Sorry if it's too much info.
Encoding started on Mon Jul 11 12:48:19 EDT 2005
-F 4
AltiVec found
CPU: PowerPC
CommandLine: '-noframedrop' '-vo' 'yuv4mpeg' '-ao' 'pcm:waveheader' '-v' '-osdlevel' '0' '/Users/mikecairns/Desktop/move.avi' '-aid' '1'
get_path('font/font.desc') -> '/Users/mikecairns/.mplayer/font/font.desc'
font: can't open file: /Users/mikecairns/.mplayer/font/font.desc
Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
Using Unoptimized OnScreenDisplay
Using Darwin accurate timing
Terminal type `unknown' is not defined.
get_path('input.conf') -> '/Users/mikecairns/.mplayer/input.conf'
Can't open input config file /Users/mikecairns/.mplayer/input.conf: No such file or directory
Can't open input config file /usr/local/etc/mplayer/input.conf: No such file or directory
Falling back on default (hardcoded) input config
get_path('movie.avi.conf') -> '/Users/mikecairns/.mplayer/movie.avi.conf'
Playing /Users/mikecairns/Desktop/movie.avi.
[file] File size is 1462284288 bytes
STREAM: [file] /Users/mikecairns/Desktop/movie.avi
STREAM: Description: File
STREAM: Author: Albeu
STREAM: Comment: based on the code from ??? (probably Arpi)
AVI file format detected.
list_end=0x2286
======= AVI Header =======
us/frame: 41708 (fps=23.976)
max bytes/sec: 0
padding: 0
MainAVIHeader.dwFlags: (272) HAS_INDEX IS_INTERLEAVED
frames total: 192534 initial: 0
streams: 2
Suggested BufferSize: 0
Size: 640 x 288
list_end=0x10F4
==> Found video stream: 0
====== STREAM Header =====
Type: sdiv FCC: divx (64697678)
Flags: 0
Priority: 0 Language: 0
InitialFrames: 0
Rate: 2997/125 = 23.976
Start: 0 Len: 192534
Suggested BufferSize: 85040
Quality 10000
Sample size: 0
found 'bih', 40 bytes of 40
======= VIDEO Format ======
biSize 40
biWidth 640
biHeight 288
biPlanes 1
biBitCount 12
biCompression 1145656920='DIVX'
biSizeImage 1105920
Regenerating keyframe table for MPEG4 video
list_end=0x217A
==> Found audio stream: 1
Type: sdua FCC: (0)
Flags: 0
InitialFrames: 1
Rate: 24000/1 = 24000.000
Start: 0 Len: 192724993
Suggested BufferSize: 12000
Quality -1
Sample size: 1
found 'wf', 18 bytes of 18
======= WAVE Format =======
Format Tag: 8192 (0x2000)
Channels: 2
Samplerate: 48000
avg byte/sec: 24000
Block align: 1
bits/sample: 0
cbSize: 18
Unknown extra header dump: [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0]
list_end=0x2286
AVI: dmlh found (size=248) (total_frames=192534)
list_end=0x22C6
hdr=Software size=44
Software : VirtualDubMod 1.5.10.1 (build 2366/release)
list_end=0x56CAA8B8
Found movie at 0x280C - 0x56CAA8B8
Reading INDEX block, 385056 chunks for 192534 frames (fpos=0x0)
AVI index offset: 0x2808 (movi=0x280C idx0=0x4 idx1=0x2EEC)
Auto-selected AVI audio ID = 1
Auto-selected AVI video ID = 0
AVI: Searching for audio stream (id:1)
AVI video size=1259983813 (192534) audio size=192724993 (192724993)
VIDEO: [DIVX] 640x288 12bpp 23.976 fps 1255.2 kbps (153.2 kbyte/s)
[V] filefmt:3 fourcc:0x44495658 size:640x288 fps:23.98 ftime:=0.0417
Clip info:
Software: VirtualDubMod 1.5.10.1 (build 2366/release)
get_path('sub/') -> '/Users/mikecairns/.mplayer/sub/'
get_path('default.sub') -> '/Users/mikecairns/.mplayer/default.sub'
Opening audio decoder: [liba52] AC3 decoding with liba52
dec_audio: Allocating 3840 bytes for input buffer.
dec_audio: Allocating 6144 + 65536 = 71680 bytes for output buffer.
Using AltiVec optimized IMDCT transform
AC3: 2.0 (stereo) 48000 Hz 192.0 kbit/s
Checking for AltiVec resampler : 0x00000002, 2
Using AltiVec optimized resampler
A52 flags before a52_frame: 0x2A
A52 flags after a52_frame: 0x2
AUDIO: 48000 Hz, 2 ch, 16 bit (0x8), ratio: 24000->192000 (192.0 kbit)
Selected audio codec: [a52] afm:liba52 (AC3-liba52)
Using (default) progressive frame mode.============================================= =============================
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
INFO: libavcodec init OK!
Selected video codec: [ffodivx] vfm:ffmpeg (FFmpeg MPEG-4)
Checking audio filter chain for 48000Hz/2ch/16bit -> 48000Hz/2ch/16bit...
[libaf] Adding filter dummy
[dummy] Was reinitialized, rate=48000Hz, nch = 2, format = 0x00000008 and bps = 2
AF_pre: af format: 2 bps, 2 ch, 48000 hz, big-endian 16-bit signed int
AF_pre: 48000Hz 2ch big-endian 16-bit signed int
[AO PCM] File: audiodump.wav (WAVE)
PCM: Samplerate: 48000Hz Channels: Stereo Format s16le
[AO PCM] Info: fastest dumping is achieved with -vc dummy -vo null
PCM: Info: to write WAVE files use -waveheader (default).
AO: [pcm] 48000Hz 2ch little-endian 16-bit signed int (2 bps)
AO: Description: RAW PCM/WAVE file writer audio output
AO: Author: Atmosfear
Building audio filter chain for 48000Hz/2ch/16bit -> 48000Hz/2ch/16bit...
[libaf] Adding filter format
[format] Changing sample format from big-endian 16-bit signed int to little-endian 16-bit signed int
[format] Accelerated endianess conversion only
Starting playback...
[libaf] Reallocating memory in module format, old len = 0, new len = 65540
[ffmpeg] aspect_ratio: 2.222222
VDec: vo config request - 640 x 288 (preferred csp: Planar YV12)
Trying filter chain: vo
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 2.22:1 - prescaling to correct movie aspect.
VO Config (640x288->640x288,flags=0,'MPlayer',0x32315659)
VO: [yuv4mpeg] 640x288 => 640x288 Planar YV12
VO: Description: yuv4mpeg output for mjpegtools
VO: Author: Robert Kesterson <robertk@robertk.com>
INFO: [yuvscaler] SVCD output format requested in NTSC norm
INFO: [yuvscaler] input: frame size: 640x288 pixels (276480 bytes)
INFO: [yuvscaler] input: frame rate: 23975999/1000000 fps (~23.975999)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: ?:?
INFO: [yuvscaler] from 640x288, take 640x288+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 720x360, 720x480 being displayed, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] Scaling uses the BICUBIC algorithm,
INFO: [yuvscaler] without line switching
INFO: [yuvscaler] without time forwarding
INFO: [yuvscaler] Without luminance correction
INFO: [yuvscaler] Without chrominance correction
INFO: [yuvscaler] black lines: 60 above and 60 under
INFO: [yuvscaler] black columns: 0 left and 0 right
INFO: [yuvscaler] frame rate: 23.976 fps
INFO: [yuvscaler] Scaling ratio for width is 8 to 9
INFO: [yuvscaler] and is 4 to 5 for height
INFO: [yuvscaler] output: frame size: 720x480 pixels (518400 bytes)
INFO: [yuvscaler] output: frame rate: 23975999/1000000 fps (~23.975999)
INFO: [yuvscaler] output: interlace: none/progressive
INFO: [yuvscaler] output: sample aspect ratio: ?:?
INFO: [mpeg2enc] Selecting SVCD output profile
++ WARN: [mpeg2enc] Generating dummy SVCD scan-data offsets to be filled in by "vcdimager"
INFO: [mpeg2enc] Encoding MPEG-2 video to /Users/mikecairns/Desktop/movie.avi.ff.mpv
INFO: [mpeg2enc] Horizontal size: 720 pel
INFO: [mpeg2enc] Vertical size: 480 pel
INFO: [mpeg2enc] Aspect ratio code: 3 = 16:9 display
INFO: [mpeg2enc] Frame rate code: 4 = 30000.0/1001.0 (NTSC VIDEO)
INFO: [mpeg2enc] Bitrate: 3742 KBit/s
INFO: [mpeg2enc] Quality factor: 3 (Quantisation = 3) (1=best, 31=worst)
INFO: [mpeg2enc] Field order for input: none/progressive
O: [mpeg2enc] New Sequence every 9999 Mbytes
INFO: [mpeg2enc] Assuming non-video stream of 260 Kbps
INFO: [mpeg2enc] Search radius: 16
INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15
INFO: [mpeg2enc] Setting colour/gamma parameters to "unspecified"
INFO: [mpeg2enc] Progressive format frames = 0
INFO: [mpeg2enc] Using default unmodified quantization matrices
INFO: [mpeg2enc] Buffering 39 frames
XXX initial v_pts=0.000 a_pos=12000 (0.500)
*** [vo] Allocating (slices) mp_image_t, 640x288x12bpp YUV planar, 276480 bytes
INFO: [mpeg2enc] SETTING AltiVec for QUANTIZER!
INFO: [mpeg2enc] SETTING AltiVec for MOTION!
INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM!
INFO: [mpeg2enc] SETTING AltiVec for PREDICTION!
0.106 ct: 0.101 69/ 69 15% 294% 1.2% 37 0
nd 39 P quant=3.00 total act= 12871.9
14% 281% 1.2% 40 0
4
9 93/ 93 14% 317% 1.1% 46 0
ct: 0.106 111/111 14% 315% 1.1% 52 0
66 P quant=3.00 total act= 21581.6
27% 1.1% 55 0
23760.5
: 0.164 ct: 0.113 128/128 14% 308% 1.1% 58 0
83.2
134 14% 335% 1.0% 61 0
rame end 91 B quant=3.00 total act= 29454.6
0.179 ct: 0.105 259/259 16% 412% 1.1% 106 0
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 17:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 05:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 15:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 2nd Nov 2007, 23:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
