Hello. I downloaded an mpeg/dat file that was 515 mb. When I played the file, there seemed to be a few minutes missing at the end, so I found another source offering the same file that was 620 mb. I renamed the first file and started downloading the second file.
In doing this, I assumed that 1.) they are the exact same files, with the second being the complete file, and that 2.) the second file would download where the first left off and all would be fine--that they'd just connect.
Problem is, it turns out they are different encodes of the same movie. Now the first file seems to have been "corrupted" by the additional 105 MB that I downloaded.
Does anyone know if I can salvage the original 515 mb file by just "deleting" the additional 105 mb? Please help!![]()
There should be no connection between the new and old file. The two should be completely seperate, unless you renamed to the same name as the new one in which case the original file would be completely overwritten. If the second download seemed to affect the first file, I would check your hard drive for some sort of mechanical problem and/or virus.
No. It's gone.
A corrupt file after sending a .3gp file via bluetooth
By ViDector in forum Video ConversionReplies: 3Last Post: 15th Aug 2011, 10:03 -
Corrupt DV Avi file
By Briansquest in forum Video ConversionReplies: 2Last Post: 15th Jul 2010, 13:01 -
Hauppauge PVR-250 creating corrupt MPEG file
By jedi34567 in forum Capturing and VCRReplies: 2Last Post: 16th Sep 2009, 00:53 -
Corrupt(?) MPEG file
By windranger in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2009, 07:06 -
corrupt dv-file
By pdehon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Nov 2007, 09:24
