i just installed this and its very easy to use, but when i press the begin output button, the whole program just closes and i dont how what to do...any help is welcomed but please dont suggest using a diff program, thanks![]()
----> adamf9898 ---->
Which tmpgenc product are you referring too ?
I'll assume tmpgenc DVD author as it seems to have the closest version nunber. If that is the case, apply the update to the latest version and see what happens.
According o your computer specs you are running Win98. According to Pegasys Inc website, 1.5 and 1.6 of TDA are Win2000 or WinXP only - especially the DVD writer component. This might also have something to do with your problem.Read my blog here.
yes srry for not telling that.... its tmpgenc dvd author v1.5 on winxp pro system... and can u pm me the link for the updates plz, thanks
ImgBurn closes itself seconds after being open
By massner in forum Newbie / General discussionsReplies: 7Last Post: 29th Feb 2012, 21:34 -
Windows Explorer closes and restarts
By WinSpecToR in forum ComputerReplies: 5Last Post: 6th Dec 2010, 12:46 -
CamStudio suddenly closes
By terrypin in forum Newbie / General discussionsReplies: 1Last Post: 21st Feb 2010, 09:40 -
TMPGenc just closes - no error msg - no rhyme or reason! Help please.
By brightsun23 in forum Video ConversionReplies: 3Last Post: 15th Jun 2007, 12:42 -
Window Closes When Back Button is Hit
By kerrex_2006 in forum ComputerReplies: 0Last Post: 8th Jun 2007, 13:01
