every time i use avisynth avs files to open an avi in virtualdub the quality is really bad. i can see where one shade of white ends and another begins, blocky, just bad quality overall. how can i fix this?
sorry
AVISource("G:\movies\Fletch.avi")
also tried
AVISource("G:\movies\Fletch.avi", true, "RGB32") with same problem
edit: just tried opening another one and all it gives me is weird black scrambles and cant see the picture at all then i tried reopening that again and all i got was green -
actually i found out that happens even if i dont use an avs file to load it
virtualdub loads all my movies with bad quality
does that mean if i save after making changes the quality will be as bad as it looks in vdub? -
Yeah, this is a codec issue.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W
Is it possible to Fix Bad Reception Artefacts with AviSynth??
By VideoFanatic in forum RestorationReplies: 6Last Post: 15th Nov 2011, 16:31 -
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 05:48 -
Does using AviSynth affect quality?
By FrozenInferno in forum EditingReplies: 8Last Post: 27th Feb 2011, 12:41 -
How to make the best quality TV RIP in Avisynth-Megui?????HELP please
By rijubrata in forum Video ConversionReplies: 10Last Post: 5th Feb 2011, 05:26 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48
