okay...I managed to get the movie.dvd thing done, but now I want to burn it to a dvd but when I insert a blank dvd disk, the movie.dvd files that I want to burn dont show up in idvd, so how can I burn the disk without another 3rd party app? using osx 10.4.1 & ffmpegx 0.9s on a powermac G4
Results 1 to 10 of 10
You might want a moderator to move this to the Mac forum and you may get better responses.
Thx redwudz,
moving you nnoidone...
Offline -
thanx redwudz & case...Originally Posted by Case
i made disk image with ffmpegx & tried to burn using disk utility - once i figured out how to do that - but it only burned about 6 min of a 2 hr file... i got a copy of toast 6 lite when i bought the dvd burner but didnt install it yet...would that work better than disk utility for burning a dvd from the ffmpegx disk image?
sorry for being such a newbie
but thanx for your help
No, I didnt ...
I was just hoping in a quicker solution ...
Have not read it through properly....
Thanks anyway Frobozz
Please start a new topic. Don't threadjack someone elses. Thanks
Mod OfflineFrancesco -
thanx! i'll give it a try & let you know how it turns out...i'm sure you're holding your breath just waitingOriginally Posted by [url=https://www.videohelp.com/tools?tool=Windows_Media_Player
thanx again evry1
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 14:53 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 14:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19
