I recently recorded some AVI files with a still camera for a friend, and want to edit some footage out of them. Unfortunately, none of the editors I load seem to want a bar of it. They are all 30 FPS MJPG, H.26 video with 8 bit mono audio, according to the programs I have managed to load them in. All I really want to do is cut bits off the start and end.
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
What I have done with problem Video files like this ,is load them into VirtualDubMod and save out as Uncompressed AVI and use them in my NLE. Other time I have also had to use quicktime.
not for all cameras (not even built in i think anyway**) -- you often have to install of the various mjpeg codecs around ...Originally Posted by celtic_druid
also then - you can use said mjpeg also in yoru fav NLE
** i tried a sample of various mjpeg files and only one opened (may of been mpeg1 anyway) untill i have a mjpeg codec installed .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
edit - yes some mjpeg support built in to virtualdub, but not for all versions it seems ...
I seem to have worked it out with Windows Movie Maker, which will do as a stopgap solution for now. Thanks for the suggestions, everyone.
Just starting to learn Avisynth, can't open mjpeg avi and others.
By bigstusexy in forum Video ConversionReplies: 34Last Post: 11th May 2014, 17:03 -
Combining and converting AVI (MJPEG) files
By vikasa in forum Video ConversionReplies: 0Last Post: 21st Jun 2010, 13:47 -
Convert AVI to Mjpeg-II or other format
By hemang in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2009, 08:23 -
prerendered subtitles on MP4 or MJPEG-AVI
By pokerpoker in forum SubtitleReplies: 2Last Post: 6th Sep 2009, 15:06 -
30FPS Progressive to PAL Interlaced? (DSC MJPEG AVI to DVD)
By ezekiel42 in forum Video ConversionReplies: 7Last Post: 8th Jul 2007, 23:53
