Note to the moderators:Please delete if I'm not supposed to post this type of question,thanks![]()
In your opinion,what burning software would you recommend for handling image files created by Exact Audio Copy![]()
BTW EAC dont support my writer.
Eg Nero , burrrn , burnatonce , EAC's new option of using CDRDAO
Thanks.
Results 1 to 9 of 9
I would prefer Nero -> simply open your CUE file with Nero
(right click -> open with add Nero thatīs it)
but itīs a question of taste -
CDRDAO is an old, tried and true app for writing cue/bin. Requires your ASPI layer to be working, but if it does, I'd go for the CDRDAO option.
/Mats -
Originally Posted by BJ_M
I'm leaning towards using burnatonce,as its well rated,free and uses the cdrdao writing app. -
yea no problem, though i read the comments and both of the first two are wrong info .
it does support DVD-R and also it is one of the few apps to support CD+G (Karaoke) ..
and the funny thing is that the cdrwin sdk is used by many other companies ... most all burning apps are based on the work of just 3 companies ..
I guess i am old school - because some of the features and tools this app has , non others do ...
but it is just part of a burning kit .. not the only one of course you need .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Video (Not movie or TV) organizer with thumbnail sheets?
By Maoukiji in forum Newbie / General discussionsReplies: 9Last Post: 28th Jul 2013, 15:38 -
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Problem making contact sheets from vids
By majax79 in forum Newbie / General discussionsReplies: 0Last Post: 13th Jun 2008, 17:26 -
cue sheet problem
By Snowcrystal in forum AudioReplies: 2Last Post: 2nd Sep 2007, 12:29 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
