  1. Hey all, I took some video off of a dvd, so it's mpeg2 with mpeg2 audio embedded (so it's just one file).
    I imported it into After Effects (version 6.0) and when I started playing it back, some parts were flashing. I'm not really sure what's going on. Anyone have any ideas?
    Thanks for your help.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    AE 6 does not handle mpeg2 well. You should import it as converted frames or convert it to avi or QT.
  3. Originally Posted by BJ_M
    I converted it to avi but then when i played it back in windows media player, the quality looked worse and the video was skipping and the audio was off sync...
    and when i converted to .mov it did the same thing pretty much.
    EDIT:
    actually, I just played the mpeg2 video in vegas5, and kinda did the same thing. It flashed and was kind of off sync with the audio.
    I did some cuts in vegas5 and rendered to mpeg2 again. The audio was off because the video was moving and super high speeds.
  4. Originally Posted by BJ_M
    AE 6 does not handle mpeg2 well. You should import it as converted frames.
    how do you do that exactly? I did a search on google but i didn't really find anything.
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    load mpeg2 into virtualdubmod and save out as targa
