i have an ATI 9200.
i connected it to my VCR.
i got the picture and sound on my PC but when i click "record" it wont capture anything.
i tried it with Ulead video studio and it sayswhat can be the problem?no video was captured. please check if there is any input signal
If this is a commercial, Macrovision-pretected tape, then nothing is wrong and the card is functioning as it is intended to in order to satisfy legal requirements.
In previous versions, this could be solved by a software hack and/or a SCM or similar device. SFAIK, there is no fix for the 9000 series cards.
Though I should note I have a 7500 and so have not looked for 9000 solutions. It was interesting that with my card, the SCM removed all visual evidence of Macrovision, but I still got the "no record" message. The software hack prevented this.
Are you certain you have properly set the cable type in both softwares? -
thankx for the reply.
actually i was recoding a family VHS tape.
i tried with uninstalling the drivers and reinstalling it and it finally worked.
thanks again.
Capturing problem
By Phoenix 37 in forum Capturing and VCRReplies: 4Last Post: 18th Jun 2011, 18:09 -
Problem Capturing DV with Windows 7
By monoxide77 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 9th Jun 2009, 15:31 -
VHS Capturing Problem
By sdculp in forum Capturing and VCRReplies: 14Last Post: 12th Feb 2008, 16:08 -
DV capturing problem
By BMR in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 25th Sep 2007, 17:19 -
Capturing Problem.
By rowie4life in forum Capturing and VCRReplies: 1Last Post: 20th Aug 2007, 09:33
